Latest: S2cgm
Overall: 17178
Online Now [68]:
Visitors: 66
Bots: 2
Today: 57491
Total: 136379271
Forums › The Car › 206 Problems › Air in fuel lines?
Air in fuel lines?
Go to page Previous  1, 2
fkismad
PostPosted: Thu Dec 23, 2010 6:21 pm Up
But if the air is coming through the pipe before going to the engine bay would this not mean the problem is in the pipes before it reaches the engine?
Francis
macj
PostPosted: Fri Dec 24, 2010 4:34 am Up
It gets into the system thruogh the returnd line... which is the pipe you have indicated
fkismad
PostPosted: Fri Dec 24, 2010 9:51 am Up
Ah i see. Will check this, thanks!
Francis
fkismad
PostPosted: Mon Jan 03, 2011 11:39 am Up
Finally got this sorted. Left it into a mechanic that found the problem lay with the little plastic connector that connects to the left hand side of the filter housing. Took this off and replaced with a new hose and jubilee clips Smile thanks for the all the help people!
Francis
Page 2 of 2
