Latest: sparrowdclxvi
Overall: 17139
Online Now [147]:
Visitors: 146
Today: 40226
Total: 113240114
Forums › The Car › 206 Talk › Door membrane alternative?
Mike
PostPosted: Tue Jan 04, 2011 4:16 pm Up
Trade Rating: +28
Basically my door membrane has seen better days and they're nearly £30 each from a dealer, and ones in scrap yards are an a**e to remove! Can you use plastic sheeting to do the job? As long as it's sealed round the edges?
meady
PostPosted: Tue Jan 04, 2011 4:18 pm Up
Trade Rating: +45
If its going to be a water tight finish then there is no reason you cant as it is doing the same job as the membrane
TEAM - I HATE FACEBOOK Smile
Dont see why not Mike
PostPosted: Tue Jan 04, 2011 4:19 pm Up
Cant see why not tbh mate, what about cardboard?
What does the membrane do exactly?
Ash
Stops water getting into the car through the door.
PostPosted: Tue Jan 04, 2011 4:21 pm Up
Ah right thanks for clearing that up mate
Cardboard as i said then is a no no lol
meady
Trade Rating: +45
The cardboard might not work as if it gets wet enough then the water might soak through still - i no it would take alot of wate but it might be possible
Ash
PostPosted: Tue Jan 04, 2011 4:24 pm Up
Plastic Sheeting and some sort of sealant should be fine imo.
PostPosted: Tue Jan 04, 2011 4:25 pm Up
Sound proofing and stops the draft thru the holes in the doors. The water should run down the inside of the door and thru the holes in the bottom.
Werdnal
PostPosted: Tue Jan 04, 2011 5:17 pm Up
We made some for a Golf I had once, which leaked like a basket the first time I put a hose on it! Local VW renovation guy made his own like this all the time. You can get clear fairly thick plastic sheeting from garden centres and DIY stores, cut from a roll.
Get some spray on adhesive, the type used by carpet fitters. Cut the sheet roughly to size, spray the adhesive on the surround of the door, fit the sheet (a 2 person job as you need to keep it fairly tight), and trim off any extra for a tidy edge.
meady
PostPosted: Tue Jan 04, 2011 5:36 pm Up
Trade Rating: +45
I would of thought mastic of sum sort would have been beter as it will make a water tight finish
Werdnal
PostPosted: Tue Jan 04, 2011 5:45 pm Up
We tried mastic first - doesn't hold the plastic sheet well. Hence spoke to the chap up the road that restores VWs for a living and he said the adhesive works better. Is meant to stick down carpet and vinyl, so its pretty waterproof. Make sure you get the carpet stuff though, as some glues are water soluble.
VorTechS
PostPosted: Wed Jan 05, 2011 2:29 am Up
Staff - Vortechs
Is a plastic sheet going to be good enough?
Isn't part of the job of this membrane to deal with the inside as well as the outside, i.e. to prevent condensation build-up?
Mike
PostPosted: Sun Jan 09, 2011 2:28 pm Up
Trade Rating: +28
Found a slightly thicker bin bag so going to use that Smile
Anyone ever used any of these glues and which one is best to stick the lining to the door? Cheers Very Happy
shop.ebay.co.uk/?_from...Categories
Andy180+
PostPosted: Sun Jan 09, 2011 3:38 pm Up
9739f9 check out this part number at your dealer, its what we use insted of the dearer made to fit membrane.
