Latest: Mr-Koekwaus
Overall: 17125
Online Now [323]:
Visitors: 322
Today: 41018
Total: 100123746
Forums › The Car › 206 Talk › Com 2000 coding
Com 2000 coding
arclight
PostPosted: Wed Jan 05, 2011 4:10 pm Up
Hey all, new to this forum, due to girlfriend having a '51 206 2.0 HDI.
Just failed MOT on indicator stalk problem, despite arguing the toss, and the fact that same garage passed it last year with same fault!
Does a new/secondhand com unit have to be coded to the BSI, or can you just plug it in?
And is it correct that the radio does not require a code after a battery disconnect?
I'm pretty sure it is multiplex, as it has the large style MFD with MPG etc. and large 'fat' stereo remote stalk.
Thanks in advance.
PostPosted: Wed Jan 05, 2011 4:15 pm Up
The COM2000 is just plug and play, but make sure you have the same amount of functions as your existing one.
The radio does not require a code.
Make sure you d/c the battery correctly. A guide can be found in my sig.
pat_986
PostPosted: Wed Jan 05, 2011 4:24 pm Up
Is that true of all the COM2000 functions?
Its just that my steering wheel position sensor has broken causing the ESP to stop working, and I was told I would have to have it reconnfigured?
Cheers
2004 Flamenco red GTi 180
arclight
PostPosted: Wed Jan 05, 2011 4:25 pm Up
Mate, thanks for the quick reply, and advice.
I already clocked the battery disconnect info.
More complex than a 747!
Got to do the rear brake drums too, and not read anything good about that job!
Thanks.
One for the road
PostPosted: Wed Jan 05, 2011 4:44 pm Up
Cheers
Yeah it should just plug and play. A new Com for the GTi180 is mega money tho
PostPosted: Thu Jan 06, 2011 3:33 am Up
Cheers
A GTI 180 or any 206 with ESP fitted is NOT plug & play.
The ESP steering angle sensor needs setting up after replacing the com2000 unit Wink
Technically you should also reset the ESP system steering angle sensor after have the wheel alignment adjusted.
PostPosted: Thu Jan 06, 2011 9:59 am Up
ahh my bad, always thought it was. Probably why they are like £400 then
PostPosted: Thu Jan 06, 2011 2:44 pm Up
Peugeot / Citroen stuff with ESP has the steering angle sensor built in to the Com2000, it saves space in installation but adds cost when it goes wrong as you have to replace the complete unit Laughing
pat_986
PostPosted: Thu Jan 06, 2011 3:32 pm Up
Thanks guys. Ever heard of this company www.bba-reman.com/cata...oduct=1711 apparently they will refurb your unit for £150?
PostPosted: Thu Jan 06, 2011 3:33 pm Up
BBA yes Wink
One of the best places around to ask if you need something electronic repairing on a car Cool
pat_986
PostPosted: Thu Jan 06, 2011 3:40 pm Up
MrBSI wrote:
BBA yes Wink
Cool, sounds like you work for them!
PostPosted: Thu Jan 06, 2011 3:43 pm Up
pat_986 wrote:
MrBSI wrote:
BBA yes Wink
Nope, just recommended them many times Laughing
pat_986
PostPosted: Thu Jan 06, 2011 3:54 pm Up
Arr OK.
So they would be a good route to fix my ESP steering angle sensor fault?
PostPosted: Thu Jan 06, 2011 3:58 pm Up
pat_986 wrote:
Arr OK.
Is it the sensor at fault OR does it just need setting back up with Peugeot Planet?
pat_986
PostPosted: Thu Jan 06, 2011 4:14 pm Up
Yes, sensor fault
