Latest: Flyin180
Overall: 17116
Online Now [39]:
Visitors: 38
Today: 950
Total: 95051867
Forums › The Car › 206 Talk › GRRRRR Clutch problems
chunkielad
PostPosted: Fri Jan 07, 2011 12:33 pm Up
Well, finally thought i had everything sorted on my new gti beast (or at least the parts in hand to sort it) and then the clutch starts! I think its just the thrust bearing as it is squeeling when the clutch goes down but is driving fine for the minute. Can you get a thrust bearing on it's own for these or is it a full kit? Tried to search the web for one and can't find one seperate.
Do you have to move the engine at all to get the gearbox off too as my brother was on about all sorts of stuff when I mentioned him fitting my new clutch.
If you do not try you will NEVER succeed!
chunkielad
PostPosted: Fri Jan 07, 2011 12:51 pm Up
Oh and what is the correct pug part number for the clutch please?
PostPosted: Fri Jan 07, 2011 12:56 pm Up
It's a false economy not to replace the whole of the clutch at the same time.
PostPosted: Fri Jan 07, 2011 1:01 pm Up
www.aepdirect.com/clut...y_id=3367#
Have a look in the discount section, there's a discount code for them as well.
benb
PostPosted: Fri Jan 07, 2011 1:02 pm Up
u ave to loosen the suspension and move them out wards to get gearbox off
1.1lx 2000 plate
chunkielad
PostPosted: Fri Jan 07, 2011 1:10 pm Up
I suppose by the time you take it all out and mess around, might as well just put a clutch in.
Lee wrote:
http://www.aepdirect.com/clutch-kit-p3620?category_id=3367#
They want £166 plus Vat and locally I can get exactly the same item for £90 + VAT. Thanks for the link anyway though.
Is that it? My brother reckons you need to loosen off the engine mounts and tip it over a bit too.
apjs87
PostPosted: Fri Jan 07, 2011 1:54 pm Up
didnt you do a thread about this the other day?
No longer a 206 owner
Astra H sxi. 1.7Cdti
chunkielad
PostPosted: Fri Jan 07, 2011 2:22 pm Up
Not me buddy. The clutch only started squeeling this afternoon.
ViperVere
PostPosted: Fri Jan 07, 2011 2:26 pm Up
Just replaced my today my clutch went bout 5 days after the release bearing started to squeal!!!
It\'s me! nothing more, nothing less!
sp5flys
PostPosted: Mon Feb 07, 2011 3:36 am Up
hi did you get it sorted, mine just started playing up the squeaking ive got a hdi i got a quote 800quid?? does that sound right?
cheers
.. Peugeot 206 2.0 D turbo hdi ..
giveitsomebar
PostPosted: Mon Feb 07, 2011 3:48 am Up
no it doesnt it should be about 200-300 quid
