Online Now [582]:
Visitors: 581
Today: 71692
Total: 146970200
Forums › The Car › Request a how-to › How to get RPM signal in the GTI 138?
Go to page Previous  1, 2
erick3.14
PostPosted: Fri Jan 07, 2011 3:44 pm Reply with quote Up
UPDATE:
today I arrived from my vacation and could wire the REV Counter. According my REV COUNTER manual, it asked to hook in the coilpack signal. Just doing that worked fine.
So I got the signal from the coilpack connector: connector 1135 4V NR according the following diagram.
Thanks Lee for your help. In my case, I needed the coil signal. The diagram you sent was the engine speed sensor directly.
Here is a video of the REV counter working. Just wondering now why the REV counter sometimes slips... I believe that the engine may not be fixed to steady RPM, so from time to time it may go over... I believe that original ECU/BSI which makes calculation for REV COUNTER and dashboard may take that into consideration and just show the average or most common data... so I guess the original system has a better filter to avoid rpm to slip. Anyway, it is fine:
206 2.0 engine swapped
Project Loading: GTI 180 interior replica construction
Next Step : turbo charge the 2.0
My project blog : swapando.blogspot.com/ (sorry for not being in English)
Page 2 of 2
  Quick Reply
Username:
Message:
Quote the last message
