Posted: Sat Jan 08, 2011 6:27 am |
Does anyone know if it's possible to bypass the aircon pump on a 1.4 8v, if so is there a diagram anywhere that would show how to do so?
Posted: Sat Jan 08, 2011 6:29 am |
Yes, you get a tensior/belt system of a TU engine without one
Swap the tensior and remove the aircon (change to different belt as well)
I should know, ive done it
| Team Impossible Possible
Posted: Sat Jan 08, 2011 6:31 am |
this may sound a bit thick, but what's the TU engine?
Posted: Sat Jan 08, 2011 6:33 am |
| [-Jebus- wrote: |
| "]this may sound a bit thick, but what's the TU engine? |
its the first part of the engine code of the peugeot/citroen 8 valve 1.1/1.4/16 engines
why do u want to remove the aircon??
| [-Jebus- wrote: |
Your engine
Its just the type, they can be:
1.1
1.4
and 1.6
Posted: Sat Jan 08, 2011 6:34 am |
the pump itself, the bearings went in it a while ago and it was replaced, now they've gone again and it sounds like an awful whine, also im trying to sell my car, so it isn't really a positive.
