Online Now [519]:
Visitors: 518
Today: 109587
Total: 154494460
Forums › The Car › 206 Problems › erratic Idling
erratic Idling
hamed206
PostPosted: Mon Jan 10, 2011 4:27 pm Up
Hello all, my car has been suffering from erratic idling which is very noticeable at the morning and quite noticeable when the car reach the normal temperature 80-90degC.
This problem is a chronic one and my car has been suffering from it 2 years later!!, it's not the stepper motor, not the IAT sensor, not the MAP sensor, not the Oxygen sensor and not the spark plugs!!, what could this problem be????
Any suggestions are welcome.
Thank you all.
Hamed
roberto.f
PostPosted: Mon Jan 10, 2011 4:49 pm Up
Faulty injector?
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
elcamino
PostPosted: Tue Jan 11, 2011 12:26 am Up
+Fuel filter........>any fault code memorized on ECU..?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Kersh
PostPosted: Tue Jan 11, 2011 1:51 am Up
coil pack or throttle position sensor. Some 206s were fitted with dodgy sagem coils that send surges of electricity to the ecu damaging the electrodes or something, a valeo coil pack might solve the problem. If not then try the throttle sensor. (Although they are pricey new!)
Member number: 36
hamed206
PostPosted: Tue Jan 11, 2011 3:19 am Up
I haven't checked the injectors, so how could I know they are the problem?
My coilpack is Bogicord not Sagem.
Regarding the TBS, I tried before a used one and the same problem exist.
Hamed
