Online Now [463]:
Visitors: 461
Members: 1
Today: 127850
Total: 156842765
Forums › The Car › Request a how-to › Fitting coilovers?
Fitting coilovers?
drunknmunky
PostPosted: Thu Jan 13, 2011 7:55 am Reply with quote Up
Anyone got a good how to on fitting coilovers? Thinking of doing some this weekend but cant quite understand how to set them up and how the old suspension comes off?
The trouble im having is that they are height adjustable but i dont know what height to set them too and how you can tell what to set them too? Its just a strut with a spring and a rubber boot and you have to cut the boot i think as its massive and also the spring seat moves up and down and i dont undestand which way to move it to set it up right?
thanks in advance Smile
PostPosted: Thu Jan 13, 2011 10:50 am Reply with quote Up
show us what parts have you got for the coilovers, so that it will be easier to tell you how to assembly it.
it is pretty straight forward
PostPosted: Thu Jan 13, 2011 12:00 pm Reply with quote Up
Something says you'll need help. and a few new nuts and bolts as they shouldn't be reused.
macj
PostPosted: Thu Jan 13, 2011 12:23 pm Reply with quote Up
Its fairly straight forward if you remember how it all comes to bits with the old stuff.... The lower spring platform is your height adjustment.... move it up and you raise the car.... then measure the first one and move the other to the same spot to level the car.... unless your a track fan then you need to add some height to the O/S to compensate for the drivers weight..... now your confused Laughing
drunknmunky
PostPosted: Thu Jan 13, 2011 12:51 pm Reply with quote Up
im not really needing much help i used to do car mechanics at college qualified to level 2 and took plenty of struts out and that its just been a while and i have never had a play with coilovers and just dont understand what height to set it to to start with as i dont want it too low but dont want it too high if you get what i mean :/
and no im not much of a track day guy never really used it on the track its mainly for looks
ill get some pics in a second and see if you can shed some light on what to do with them Smile
PostPosted: Thu Jan 13, 2011 12:55 pm Reply with quote Up
Just set the spring seat mid way along the strut...suck it and see.
drunknmunky
PostPosted: Thu Jan 13, 2011 1:04 pm Reply with quote Up
heres some pics Smile
why is one of the top bits pushed right in and the other sticks out a lot should they not both be the same?
sorry bout the crap quality taken on my phone as i left my digi cam charger at work Sad
PostPosted: Thu Jan 13, 2011 1:09 pm Reply with quote Up
is just because the strut is not fully lifted. you don't have to cut the dust shield.
the silver one is the top spring pan. you will need to use oem top mount
btw, how come it is pink! lol
drunknmunky
PostPosted: Thu Jan 13, 2011 1:13 pm Reply with quote Up
any advice on where to seat the spring to start with and also once seated can i move it to go lower without having to take the whole thing off the car?
how will i fully lift the strut then or does it not matter about that?
it said in the instructions with them that i would have to cut it off :/ i dont really want to though tbh so i will take your advice and not cut it off Very Happy
i understood that i would have to use oem top mount just hope all my bits and bobs are alright like my bearing and that i cant really afford to fork out on new top mounts to fit them to, i should be okay using the old ones shouldnt i? they have only covered 28,000 miles
PostPosted: Thu Jan 13, 2011 1:14 pm Reply with quote Up
Do they have internal bumpstops?
drunknmunky
PostPosted: Thu Jan 13, 2011 1:18 pm Reply with quote Up
not as far as i know :/
but i have a link to the guide lines to fitting them and it says they would be supplied if they are needed
AVO Guidelines
PostPosted: Thu Jan 13, 2011 1:21 pm Reply with quote Up
Those silver top spring seats with replace the old ones. On the picture below the bearing and standard spring seat are fitted together, you'll need to separate yours.
Have a look in here, Page 15 and 16 roughly. If you've not done the suspension on a 206 they might be helpful. They were from a 'How to' I did on the old 206 info site before it died.
s38.photobucket.com/al...105/s1pso/
PostPosted: Thu Jan 13, 2011 1:22 pm Reply with quote Up
i doubt they will have internal bumpstop as they are not inverted strut, but you can always use the oem one.
PostPosted: Thu Jan 13, 2011 1:23 pm Reply with quote Up
and when you remove the bearing from the spring seat, 9 out of 10 you will distroy the bearing Laughing
PostPosted: Thu Jan 13, 2011 1:25 pm Reply with quote Up
Mine popped out nicely. But that's because I was fitting new ones. If you don't have new ones your old ones will fall apart. It's just the way it is...
  Quick Reply
Username:
Message:
Quote the last message
