Latest: S2cgm
Overall: 17178
Online Now [508]:
Visitors: 507
Today: 49842
Total: 136371640
Forums › The Car › 206 Problems › struts
struts
thompson69
PostPosted: Fri Jan 14, 2011 8:38 am Up
hi im on tryin 2 change my struts on my 1999 206 but i cant get it away from the hob is the any other way 2 do this??
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
PostPosted: Fri Jan 14, 2011 8:40 am Up
pop out the driving shaft first, and then hammer the strut out
20619d
PostPosted: Fri Jan 14, 2011 8:41 am Up
have u soaked it in wd40 then hit with big hammer to losen it abit. that wot i did then push f*****g hard
thompson69
PostPosted: Fri Jan 14, 2011 8:42 am Up
does the bolt have 2 come out the bk of the hub?
thompson69
PostPosted: Fri Jan 14, 2011 8:44 am Up
yer its socked but still no good
PostPosted: Fri Jan 14, 2011 8:45 am Up
the only bolts you have to remove is the pinch bolts
20619d
PostPosted: Fri Jan 14, 2011 8:47 am Up
mine was a pain in end we had push hard and push towards back of the car and it came out then. it hard on your own tho as i found out when dad poped out for abit but i got it out.
thompson69
PostPosted: Fri Jan 14, 2011 12:26 pm Up
thanks alot one down one to do lol
PostPosted: Fri Jan 14, 2011 2:51 pm Up
Hub off the ball joint first then knock the hub off the damper. You know how to get the hub off the wishbone?
thompson69
PostPosted: Sat Jan 15, 2011 8:53 am Up
done now thanks
