Latest: flipflap
Overall: 17140
Online Now [102]:
Visitors: 101
Today: 32038
Total: 113687832
Forums › The Car › 206 Problems › AIR BAG LIGHT STAYS ON
stevedude
PostPosted: Fri Jan 14, 2011 11:13 am Up
hello peeps, me again, ive looked throu previous topics but cant find this issue, but im sure its in there somewhere lol.
qwik fit said they can sort it for £25 but said it might come back again, so im thinking if they can fix it, so can I.
any ideas chap?
also on the matrix front, on inspection i found it only had 1 bolt holding the pipes from bulk head to matrix, so now ive fitted 2 more im hoping this was the problem. i pulled carpet up and no rust under that, its got a very think coating of plastic stuck on under side of carpet so dont worry about puddles to much, its just a wet carpet
Smile
Happydays
PostPosted: Fri Jan 14, 2011 11:24 am Up
Kwik fit will fix it for £25?! Get that in writing, it cost me just shy of £500.
Start by checking the wiring under the seats if you have side airbags.
PostPosted: Fri Jan 14, 2011 11:26 am Up
Needs a scan else your p**sing in the wind.
Most likely needs a new com2000 unit Laughing
Big_Rich180
PostPosted: Fri Jan 14, 2011 11:30 am Up
That is your response to everything though Laughing
Its most likely the wiring under one of the seats, it is a very common problem.
PostPosted: Fri Jan 14, 2011 11:35 am Up
Only if its got side airbags fitted Wink
Big_Rich180
PostPosted: Fri Jan 14, 2011 11:37 am Up
There is that i suppose Laughing DOH!!!
PostPosted: Fri Jan 14, 2011 11:38 am Up
It can also be a faulty Com2000 unit, likely to be that.
Airbag ECU, poor connection to the steering wheel airbag, wiring issue or seatbelt pre-tensioners.
PostPosted: Fri Jan 14, 2011 12:43 pm Up
What He Said
stevedude
PostPosted: Fri Jan 14, 2011 12:48 pm Up
well thats confused me alright, dont think she has side bags? but ive only had her 2 days so might be wrong lol
nopt had drivers seat up yet, ill do that next day off, she needs a bloody good clean inside, looks like she was a kids playground for a while, i even found a spiderman sliper and an monster type action figure under passenger seat lol
i now know she was broken into a while ago, glass under seat, and car areal is cut.
Happydays
PostPosted: Fri Jan 14, 2011 12:51 pm Up
Green connector plug under each front seat will be for the side airbags IF they are fitted.
stevedude
PostPosted: Fri Jan 14, 2011 1:01 pm Up
there was no wires under passenger seat, so no side bags then lol
Happydays
PostPosted: Fri Jan 14, 2011 1:05 pm Up
If you could scan it with Peugeot planet / Citroen Lexia that would easily & very quickly point you in the right direction of the fault.
Its most likely the com2000 unit.
That's the complete light / wiper stalk assembly & steering wheel has to come of to change it, don't bother with a 2nd hand / used one, fit eithera new or a service exchange unit
Really need's a scan first to pinpoint the fault Wink
stevedude
PostPosted: Fri Jan 14, 2011 1:36 pm Up
are com2000 units much dosh?
Happydays
ukskater01
PostPosted: Fri Jan 14, 2011 1:47 pm Up
Mines pre plexed but I got mine scanned and it had an open circuit on the passenger airbag. When I got my alarm fitted the sparky hard wired the original plugs under the glovebox and it hasn't come back.
Try and get it scanned first, most garages should be able to do it or get someone in to do it for them
good luck!
PostPosted: Fri Jan 14, 2011 2:16 pm Up
Depends where you buy it from.
If your keeping the car for a while then a service exchange OR new unit is the best way.
Plenty of people around that sell new one's / refurbish them.
