Latest: heikkisj
Overall: 17126
Online Now [445]:
Visitors: 444
Today: 22895
Total: 100355856
Forums › The Car › 206 Talk › Help Please !
Help Please !
Callum206
PostPosted: Tue Jan 18, 2011 1:43 am Up
Basically in desperate need of a rear left door for my 5dr pug and i cant find any EZR the one i have found has minor (By the looks of the pic) scratches and i wondered if these would be easily removable ? Thanks.
CLICK HERE
PostPosted: Tue Jan 18, 2011 1:46 am Up
They do look just like light scratches and not deep into the paintwork so im sure that you would be able to spray up or fill them and spray mate
Callum206
PostPosted: Tue Jan 18, 2011 2:00 am Up
Do you think if i took it to a detailer they'd be able to sort it ?
PostPosted: Tue Jan 18, 2011 2:10 am Up
Yeh should be able to quite easily mate, though i would first get a quote before you buy the door as you might be just better off getting your door sprayed
Im in the same situation, ive had a quote of a respray at £80 and a used door at £50 but not sure if it has scratches but id go for it if its just light scratches
there's also a how to on here which shows you how to fill scratches and respray perfect, think Ste did it
Callum206
PostPosted: Tue Jan 18, 2011 2:12 am Up
Cheers man, and yeh my door is ruined and this was the only door i could find anywhere for sale soo i really not sure on what to do.
PostPosted: Tue Jan 18, 2011 2:18 am Up
tbh mate id sum up a respray and sum up that door plus the petrol costs going to get it and see whats best because you will have to strip down the door and put the mechanism in wont you and change the lock barrel
Callum206
PostPosted: Tue Jan 18, 2011 2:23 am Up
Yeh i guess that door there is £47.25 posted and the door is stripped already is the swap of the other stuff not easy ? Because with my current door id have to pull the dent out fill it spray it and the dent is creased soo not sure if it would even look right. Another problem is, is it easy to swap the windows over because of my tints....
PostPosted: Tue Jan 18, 2011 4:43 am Up
Yeah windows are the easiest bit, umm well ive looked into it and the window mechanism is rivited on which means you will have to drill them out, once youve done that the window comes out. Then with the mechanism re-attatch to the new door shell and im not sure about changing the lock barrels, its best to just figure it out as you go along which is how i do it lol, just depends if your that type of person who would have a go
Really good price for that mate so id go ahead and have a go, just take your time doing it, also if its already stripped all you need to do is take off your bits and put them in the new frame, you wont have to mess around stripping that door aswell
