Latest: Mr-Koekwaus
Overall: 17125
Online Now [47]:
Visitors: 46
Today: 3742
Total: 100182439
Forums › The Car › 206 Problems › drivers seat hight adjustment?
nicp2007
PostPosted: Tue Jan 18, 2011 5:37 pm Up
hi
i have just bought a gti and the hight adjustment don't work on the drivers side,
is there a fix for this or even just a way to get it to the lowest setting and keep it there??
thanks
Nic
Thanks\r\nNic\r\nwww.prideandperformance.co.uk
PostPosted: Tue Jan 18, 2011 5:38 pm Up
Whats not actually working on the height adjustor?
Normally you sit on the seat, pull the handle up, seat will drop down & back then let go of the handle & the seat should stay there.
nicp2007
PostPosted: Tue Jan 18, 2011 5:40 pm Up
the handle don't feel right when you pull it and you can pull it and then jump up and down ant it won't move?
matcarlin24
PostPosted: Wed Jan 19, 2011 4:17 am Up
ahh no mate i had this happen on my passenger side you could move it to let people in but you couldnt adjust the tilt luckily it was covered under warranty but i have no idea what caused it but i think it might only of come of something or there a 2p stuck or somethin lol
206 Moonstone 1.4 8v Wink
doggydoctor
PostPosted: Wed Jan 19, 2011 5:06 am Up
Does the adjustment lever feel very loose? Mine came back from the dealer with a loose adjuster after it had been in for something completely different.
If you take the seat out, you should be able to see a loose pin that is normally welded in place on the side of the seat frame. If you have a welder, you should be able to push the pin back in it's normal place and weld it in place. If you don't have a welder, like me, you can use a 40mm long mate bolt. Measure the length of the thicker part of the original pin and cut a length of aluminium pipe to act as a shim. then push that into place, nut at the end and it should work again.
Twidly
PostPosted: Wed Jan 19, 2011 6:09 am Up
You're talking about something completely different. Wall Bang
matcarlin24
PostPosted: Wed Jan 19, 2011 7:11 am Up
ALRIGHT jesus i'm just saying I had a similar problem but on the passenger seat it was stuck in a posistion and i couldn't adjust it and the handle would be fine to let people in but adjustin the tilt it was like the handle was stuck. I was just making a point that it's most probably something stupid like easily fixed!!!!!!! So just read what i said instead of trying to be the ultimate knowledge I know how much of a wounder it is so I was trying to HELP
nicp2007
PostPosted: Wed Jan 19, 2011 2:48 pm Up
thanks guys,
quit the domestics though lol
i have sorted it, i just pulled it with all my might and jumped up and down and it started to come free,
no it is working fine Very Happy
brute force and ignorance sometimes is the best way,
Twidly
PostPosted: Wed Jan 19, 2011 3:23 pm Up
You're still talking about the wrong handle.
He's on about the one to the front and left of the drivers seat... makes the seat go up & down, not tilt. Very Happy
Ash
PostPosted: Wed Jan 19, 2011 3:38 pm Up
My seat works fine. Just saying.
Twidly
PostPosted: Wed Jan 19, 2011 3:39 pm Up
Yeah mine too Whistle...
Ash
PostPosted: Wed Jan 19, 2011 3:40 pm Up
Life is good henneh Razz
stevedude
PostPosted: Wed Jan 19, 2011 4:06 pm Up
as we talking seats lol, anyone else find putting there seat belt on a pain in the a**e?
mine always catches between the seat tilt thingy and the door!
Happydays
dan_206
PostPosted: Wed Jan 19, 2011 4:15 pm Up
Yeah but that's cause my belt has part twisted behind the rear doorcards and doesn't retract as it should. Gunna sort it this weekend Smile
nicp2007
PostPosted: Thu Jan 20, 2011 11:45 am Up
yes this is a pain,
i used to get annoyed with it in hannah's quicksilver and now my gti does the same thing Sad
is it just the sport seats that this happens with or all the seats?
