Online Now [707]:
Visitors: 706
Today: 142285
Total: 155234569
Forums › The Car › 206 Problems › Just done my head gasket
smccullie
PostPosted: Wed Jan 19, 2011 10:43 am Up
I have just done the head gasket on my 206 1.4(ac) and now the coolant temp guage wont work?? i have checked the plugs and the 2 on the thermostat area are pluged in, top hose get hot so i think the thermostat is opening, anyone got any ideas???
206 1.4 t reg
Luke
PostPosted: Wed Jan 19, 2011 11:27 am Up
Does it just not work or does it give a false reading?
smccullie
PostPosted: Wed Jan 19, 2011 12:14 pm Up
just not working at all moves up a few mm then nothing
206 1.4 t reg
troy
PostPosted: Wed Jan 19, 2011 12:30 pm Up
air lock in the cooling system?
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
Ape
PostPosted: Wed Jan 19, 2011 2:03 pm Up
Sounds like an air lock to me. Did you bleed the system?
mattievrs
PostPosted: Wed Jan 19, 2011 2:04 pm Up
This
NO LONGER ACTIVE ON THE FORUM
smccullie
PostPosted: Thu Jan 20, 2011 1:47 am Up
there is coolant coming out the bleed screw at the bulk head hose, top rad hose gets hot so there is coolant there, if it was an air lock would the temp not work sometimes then stop again??
206 1.4 t reg
Ape
PostPosted: Thu Jan 20, 2011 2:11 am Up
There are 2 other bleed screws if I remember rightly? On on the thermostat housing and I can't remember the other, been a while since I had a 206 in bits.
smccullie
PostPosted: Thu Jan 20, 2011 2:13 am Up
I am going to have a play about with this today then go buy a sensor if i get no where, how to i test if the fan is working do i just disconect the ac sensor ???
206 1.4 t reg
Ape
PostPosted: Thu Jan 20, 2011 3:19 am Up
Unplugging the coolant temp sensor normally kicks the fan in and your needle hit the red as it loses signal
smccullie
PostPosted: Thu Jan 20, 2011 4:14 am Up
ok missed a plug the one at the side of the head, gauge works now, next problem the hose at the bottom of the filler bottle blew off when i was bringing upto temp
206 1.4 t reg
smccullie
PostPosted: Thu Jan 20, 2011 4:15 am Up
ohh ye forgot to ask what temp should the fan kick in at
206 1.4 t reg
