Latest: DanDan17
Overall: 17128
Online Now [50]:
Visitors: 49
Today: 12432
Total: 100440147
Forums › The Car › 206 Talk › Wing mirror casing replacement
-RAJ-
PostPosted: Sun Jan 16, 2011 9:40 am Up
managed to scrape my wing mirror on a wall so was wonderind if it is possible to just replace the main body and not the mirror ect?
cheers Smile
PostPosted: Sun Jan 16, 2011 9:42 am Up
Yes BUT its a fiddly job stripping the mirrors down.
You'd need to buy the whole mirror to get the casing anyway
-RAJ-
PostPosted: Sun Jan 16, 2011 9:43 am Up
was thinking about buying a manual one as they are cheaper and changing my electrics over
PostPosted: Sun Jan 16, 2011 9:46 am Up
Turn the mirror glass so it faces the car, unclip the two metal things that hold the glass on. Then the internals are all T15 screws I think, be very careful as the plastic is brittle and it snaps easy. On the underside of the mirror casing, there is also a couple of screws.
-RAJ-
PostPosted: Sun Jan 16, 2011 9:52 am Up
sweet thanks for your help, was thinking it may be a fixed unit or something, ill give it a go and see what happens lol
kingdom200
PostPosted: Mon Jan 17, 2011 11:42 am Up
could this be done with a gti wing mirror casing replacing a 180 one? because my wing mirror is fine and so are the elctronics its just a stupid bracket that has snapped and a gti wing mirror is almost 100 cheaper!
PUG1OFF Cat Cams/ ECU project
-RAJ-
PostPosted: Wed Jan 19, 2011 5:26 pm Up
i found this, by the looks of it, it can be done Smile
www.206info.co.uk/Foru...=3745.html
