Posted: Thu Jan 20, 2011 4:48 am |
When going around a roundabout or a sharp bend the handbrake light flickers until I come off the roundabout or bend. Anyone have any ideas on what is causing this?
| | ![](images/spacer.gif) |
Posted: Thu Jan 20, 2011 5:07 am |
Low brake fluid.
Posted: Thu Jan 20, 2011 5:10 am |
brake fluid is low.
brake fluid is low.
Posted: Thu Jan 20, 2011 5:11 am |
| 2004 Flamenco red GTi 180 | |
Posted: Thu Jan 20, 2011 5:13 am |
OR your pads are getting low
| Hi Mikey ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Thu Jan 20, 2011 5:17 am |
Cheers guys. I'm having my brake pads done on the weekend. So the brake fluid will be checked then.
Posted: Thu Jan 20, 2011 5:19 am |
sillyhilly wrote: |
OR your pads are getting low |
True.
Posted: Thu Jan 20, 2011 6:15 am |
Are the rear brakes easy to change? I'm having the front done this weekend. I read before that special tools are required for the rear brakes. I'm having a friend do them who used to be a mechanic.
Posted: Thu Jan 20, 2011 6:18 am |
supacook2k wrote: |
Are the rear brakes easy to change? I'm having the front done this weekend. I read before that special tools are required for the rear brakes. I'm having a friend do them who used to be a mechanic. |
No, you just need some long nose pliers or a long, flat headed screwdriver to wind the piston back in.
Posted: Thu Jan 20, 2011 6:45 am |
supacook2k wrote: |
When going around a roundabout or a sharp bend the handbrake light flickers until I come off the roundabout or bend. Anyone have any ideas on what is causing this? |
Does the STOP warning light come on at the same time?
Posted: Thu Jan 20, 2011 7:41 am |
check the handbrake button under the handbrake
Posted: Thu Jan 20, 2011 7:05 pm |
MrBSI wrote: |
supacook2k wrote: |
Does the STOP warning light come on at the same time? |
nope. just the handbrake light
Posted: Fri Jan 21, 2011 5:50 am |
supacook2k wrote: |
MrBSI wrote: |
supacook2k wrote: |
nope. just the handbrake light |
Check the handbrake switch & wiring then, as a test swop it for the glovebox light switch as there exactly the same part ![Wink Wink](images/smiles/icon_wink.gif)
