Online Now [40]:
Visitors: 38
Bots: 2
Today: 34642
Total: 116577025
Forums › The Car › 206 Talk › Arb Brushes
Arb Brushes
Danny.
PostPosted: Fri Jan 21, 2011 4:50 am Up
How hard are Arb Brushes to change?
And what is involved in changing them?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Fri Jan 21, 2011 4:53 am Up
Very simple job actually, but made easier if you remove/change the droplinks at the same time.
Undo the large torx bolt (very stiff so use a long breaker bar) un-hook the metal housing, remove rotten bush & replace with new (New bushes on the GTi are £5 each IIRC) then latch the metal bracket back on, tighten torx bolt & replace droplinks.
Repeat on the other side.
Danny.
PostPosted: Fri Jan 21, 2011 4:56 am Up
Looks like you talking foreign :L
Umm what large torx screw... I dont even know wwhere abouts they are
PostPosted: Fri Jan 21, 2011 5:00 am Up
Hang on I'll get you a diagram.
PostPosted: Fri Jan 21, 2011 5:02 am Up
No.2 is the bush & 70 is the bolt.
The bushes are £8.93 for the GTi ones but will be different for your 206.
Big_Rich180
PostPosted: Fri Jan 21, 2011 5:04 am Up
To be fair if you dont know what a torx screw is maybe you should pay someone to do it Laughing
PostPosted: Fri Jan 21, 2011 5:06 am Up
Actually it's more of a reverse torx bolt. See No.70
Danny.
PostPosted: Fri Jan 21, 2011 5:20 am Up
I know what a torx screw is.....
I didnt know where he was talking about..
Big_Rich180
PostPosted: Fri Jan 21, 2011 5:33 am Up
Ahhh fair enough Laughing
PostPosted: Fri Jan 21, 2011 7:25 am Up
No need to remove drop links from the car. Just unbolt both ARB clamp and it drops down nicely.
