Posted: Sun Jan 02, 2011 1:42 pm |
| macj wrote: |
| love it...... will be a treat to drive with the wider track |
Cheers mate its taking way too long to build tho but should be worth it when finished
Posted: Sat Jan 08, 2011 4:42 am |
BTW if you know where else to get a rear tailgate glass apart from P4P then let me know... I cant get an answer from them
Posted: Fri Jan 21, 2011 6:04 pm |
| macj wrote: |
| BTW if you know where else to get a rear tailgate glass apart from P4P then let me know... I cant get an answer from them |
I got complete window kit from P4P was a bit of a wait for it to arrive but very happy with quality
quick update:
finished off all interior wiring,fitted internal fuel lines,fitted all pipe work and jets for fire extingusher,
got my dash back from flocking and have it fitted
camera batt flat will post pics later
Posted: Sat Jan 22, 2011 4:22 am |
Your on the good bit of the build now.... Its nice when it all starts to go back together
Posted: Tue Jan 25, 2011 5:57 pm |
Few pics of progress
Dash trimmed down and test fitted
[/img]
Fuel lines & fire ex pipework fitted
Dash Flocked and fitted
Posted: Sat Apr 09, 2011 1:39 am |
For some reason I seem to have missed this last posting... looking good mate... where are you now with it?
Posted: Sat Apr 09, 2011 2:24 am |
Nice meeting you today Brian
The Turinis and Chronos will suit this right down to a tee
Looking forward to seeing this finished.
Posted: Sat Apr 09, 2011 2:38 am |
very nice, im currently at the stage you were in 2010! lol. im not rushing to finish tho
Posted: Tue Apr 12, 2011 3:50 pm |
Cheers for comments lads
I have made small bits of progress since got engine fitted and started making loom,
got myself a heated windscreen and wheels
plan is to get few hours this week to finish looms
no real pics but will post up a few soon
Posted: Sun Nov 27, 2011 10:06 am |
I sort of had lost interest in this for while but after break away from it i got stuck in again
I took back out orignal rear axle i got a 206SW rear axle but it had drum brakes, so i converted it to use 288mm front discs used the callipers from front brake kit i had and widened the track of axle by 160mm,removed the orignal anti roll bar and fitted adjustable ARB and finally fitted alloy Peugeot Sport axle bushings.
Other bits done are
Front driveshafts are now sorted and fitted
Peugeot Sport sump guard fitted
Fitted Front Heated windscreen & 1/4 windows
have set a deadline to do my local Tarmac Stages Rally at end of Feb so will have regular updates on this
next on list is finish bodywork then engine & gearbox rebuilds
here are a few pics of progress
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
Posted: Sun Nov 27, 2011 10:14 am |
Its coming on nicely mate..... very big brakes on the rear
Posted: Sun Nov 27, 2011 12:24 pm |
Love how clean and bright the boot floor is...what's the rules on having a cable operated hardbrake on the rear?
Posted: Sun Nov 27, 2011 12:47 pm |
| Edward wrote: |
| Love how clean and bright the boot floor is...what's the rules on having a cable operated hardbrake on the rear? |
It has to lock the wheels on the operation of the lever and remain locked with the hand removed from the lever. The usual way round it on a hydraulic handbrake is to fit a pin in the lever to hold it on
Posted: Sun Nov 27, 2011 12:57 pm |
| macj wrote: |
| Edward wrote: |
It has to lock the wheels on the operation of the lever and remain locked with the hand removed from the lever. The usual way round it on a hydraulic handbrake is to fit a pin in the lever to hold it on |
Posted: Sun Nov 27, 2011 1:09 pm |
Trade Rating: +31
simply stunning
