Posted: Sat Jan 22, 2011 6:21 am |
Was driving last night to a friends house and i went on a dual carriage way was driving to about 80mph then as i was getting off at my exit i was slowing down stopped at a roundabout and the speedometer was still on 40mph, continued driving and it acted like 40mph was 0 and just kept going up till like 90, when i got to my friends house it stopped on 50mph and i realised once i turn the car on and off it drops by 5 on the speedometer so i done that till it dropped to 0 now it goes up and down normally but it sometimes stops on 10 or 5 mph when im not moving -.- really got on my nerves
Anyone know how to fix it ?
Posted: Sat Jan 22, 2011 7:00 am |
Year of 206?
ABS fitted or not?
If its fitted is the ABS light on?
There's 2 different way's the speedo work's on a 206 depending on age & ABS fitment, give us some clue what we are dealing with & we can then help you further
Posted: Sat Jan 22, 2011 7:29 am |
mine has a similar problem but inversed, i was doing 80-100kmh and the speedo gives me 40 maybe 50
and the level indicator seems to shrug not movee smoothly...as if its to heavy to move up! lol
mine is a 1999 1.4l
tanks
Posted: Sat Jan 22, 2011 7:46 am |
just had a look at the tyres and i had 3 tyres changed to brand new ones 3 tyres are 175/65 and one is 165/65 the tyre place gave me 1 wrong tyre , could that cause anything with what im experiencing
Posted: Sat Jan 22, 2011 7:49 am |
almir92 wrote: |
just had a look at the tyres and i had 3 tyres changed to brand new ones 3 tyres are 175/65 and one is 165/65 the tyre place gave me 1 wrong tyre , could that cause anything with what im experiencing |
Not really.
Quote:: |
Year of 206?
ABS fitted or not?
There's 2 different way's the speedo work's on a 206 depending on age & ABS fitment, give us some clue what we are dealing with & we can then help you further |
Posted: Sat Jan 22, 2011 7:54 am |
its a 2000 peugeot 206 1.4 lx, not sure it has ABS fitted but this picture is from today while i was idle at traffic lights
Posted: Sat Jan 22, 2011 8:38 am |
Its most likely the speedo itself at fault, the speedo needle can become loose or sticky.
A spot of WD40 or superglue in the right place normally fixes it depending on which of the 2 common faults you have
78k miles, hope you have had the timing belt replaced recently
Posted: Sat Jan 22, 2011 11:08 am |
i have noticed when its dropping it doesnt do it smoothly it judders and flick's from 20 to 10 or from 20 to 0 recently its been staying on 0 even though im driving
Posted: Sat Jan 22, 2011 4:07 pm |
anyone?
Posted: Sun Jan 23, 2011 8:36 am |
Ive already answered your question, a drop or two of WD 40 will fix it.
Posted: Sun Jan 23, 2011 10:03 am |
on the pin underneath the needle?
Posted: Sun Jan 23, 2011 10:23 am |
I replaced the timing belt last month and btw my speedo in KM only it has no miles dunno for what reason.....but i prefer km so.. better for me but it stills bugs since near a speed camera i cannot know how fast im going
is there a topic on how to get the speedo out? thanks
Posted: Sun Jan 23, 2011 10:29 am |
almir92 wrote: |
on the pin underneath the needle? |
Yeah, very carefully, a couple of drops down the hole & gentle move the needle about to work the lube in.
Posted: Sun Jan 23, 2011 10:31 am |
egouder wrote: |
is there a topic on how to get the speedo out? thanks |
Pull the plastic dash surround off to unclip it.
Undo the one torx screw at the top of the instrument cluster.
Lift / unclip the cluster from the dash & undo the electrical connections on the back.
Posted: Sun Jan 23, 2011 12:54 pm |
tried the wd40 and superglue stuff and same result, gonna just get another speed clock, does anyone know what i will need to look for? a year 2000 1.4 lx what clock would i need and will the mileage stay the same?
