Latest: Andyblue64
Overall: 17123
Online Now [330]:
Visitors: 329
Today: 12101
Total: 98283733
Forums › The Car › 206 Problems › Alarm and Key fob not working
Keebs
PostPosted: Sat Jan 22, 2011 12:01 pm Up
Newly charged battery fitted, I now have no alarm LED and the key fob does not work..... Any suggestions... Cheers
Keebs GLX
chunkielad
PostPosted: Sat Jan 22, 2011 12:02 pm Up
Do a search - there is a reprogramming sequence to follow but it is specific to your car (age and model)
If you do not try you will NEVER succeed!
PostPosted: Sat Jan 22, 2011 12:05 pm Up
Give us some clues
Non plexed or multiplexed 206?
If it was plexed did you shut down / boot the BSI up correctly?
Keebs
PostPosted: Sat Jan 22, 2011 12:10 pm Up
2003 GLX.... Plexed Non-Plexed???? Have found reprogramming site but I have no LED
Keebs GLX
PostPosted: Sat Jan 22, 2011 12:12 pm Up
Your 206 is MULTIPLEXED Wink
Start the engine
Press & hold the UNLOCK button on the key fob for 10 seconds.
Hope you shut down / booted the BSI up correctly as that can stop things like remote locking working Wink
Read this for info on the BSI & how to disconnect / reconnect the battery correctly Wink
www.206info.co.uk/Foru...tboot.html
Keebs
PostPosted: Sat Jan 22, 2011 12:28 pm Up
Cheers, it's given me a starting point.... Could be back though
Keebs GLX
PostPosted: Sat Jan 22, 2011 12:35 pm Up
Shut down then reboot the BSI correctly & see if that improves things.
Keebs
PostPosted: Sun Jan 23, 2011 8:36 am Up
All sorted, great advice thanks
Keebs GLX
PostPosted: Sun Jan 23, 2011 8:38 am Up
Does your alarm arm only on the deadlocks? ( one press )
OR
Does it also arm on normal locking? ( two presses )
Red alarm led come on & stay on if the doors are locked with engine running?
Keebs
PostPosted: Sun Jan 23, 2011 1:00 pm Up
Alarm arms with first press, no indicator flash on second press. LED flashes when car is armed... No LED if door lock button is pressed when engine is running
Keebs GLX
PostPosted: Sun Jan 23, 2011 1:52 pm Up
Old / pre December 2007 BSI software version then Wink
