Online Now [1032]:
Visitors: 1031
Today: 27312
Total: 155328344
Forums › The Car › 206 Problems › The Engine Management Light?
peachypeachez
PostPosted: Sat Jan 22, 2011 3:03 pm Up
Hey guys im looking at buying a black 2003 5 door 1.4 LX, i can get it for £1300 with the engine management light on, they said they have run diagnostics tests and there is a problem in the ECU, how much am i looking at getting this fixed?
Cheers and sorry if it seems an idiotic question? :S
Kim xxxxx
'PeachyPeachez'
Metallic Black 206 1.4 LX 5dr 2003
dturbopeck
PostPosted: Sat Jan 22, 2011 3:11 pm Up
any fault codes?
peachypeachez
PostPosted: Sat Jan 22, 2011 3:17 pm Up
No i havent been given any was just told they would have sold it for £2000 if the light werent on? x
'PeachyPeachez'
dturbopeck
PostPosted: Sat Jan 22, 2011 3:45 pm Up
all depends whats wrong with it! if its the ecu might cost £300- £800, if it was me i wouldnt be buying a car i didnt know what was wrong with it as its abit of a gamble and could end up costing £1000s
peachypeachez
PostPosted: Sat Jan 22, 2011 3:48 pm Up
They have now told they will get the code for the problem monday Smile Where will i find what code means what and how much it will cost? Smile
'PeachyPeachez'
only if you can knock the price down to 700, otherwise i would stay away from this
dturbopeck
PostPosted: Sat Jan 22, 2011 3:49 pm Up
just post the code on here, and we will try and help.
peachypeachez
PostPosted: Sat Jan 22, 2011 3:54 pm Up
Thanks Guys Smile
'PeachyPeachez'
peachypeachez
PostPosted: Mon Jan 24, 2011 2:54 pm Up
Hey guys the code on the engine management light diagnostics test is PO400 can anyone shed any light? How much will this cost and whats the problem?
Kim x
'PeachyPeachez'
paulrushton
PostPosted: Mon Jan 24, 2011 3:26 pm Up
That code relates to exhaust gas recirculation flow error. It could be the EGR that's knackered or just needs cleaning out.
Peugeot 206 GTI HDI Black
Problems with your EGR. Either dodgey wiring or the solenoid/valve has gone.
peachypeachez
PostPosted: Mon Jan 24, 2011 3:33 pm Up
At its worst how much can that set me back? The car has a buy it now £1300 tag on it with this problem. Ill give you link and you guys tell me honestly whether to bother or not?
cgi.ebay.co.uk/ws/eBay...K:MEWAX:IT
Cheers
Kim
'PeachyPeachez'
PostPosted: Mon Jan 24, 2011 3:38 pm Up
If thats the only fault, it should be a cheap fix. Could try cleaning it, or get one from another car thats been broken.
deanparkr
PostPosted: Mon Jan 24, 2011 5:25 pm Up
Thats the problem with buying cars over ebay. Not all faults will be revealed by a fault code scanner.
It might be much easier and stress free to find a local car that you can visually inspect / test drive. etc. Or just take someone who "knows" about cars who can visually, audibly tell you if everything is in order
2002 1.4LX
