Latest: DanDan17
Overall: 17128
Online Now [147]:
Visitors: 146
Today: 16270
Total: 100616689
Forums › The Car › 206 Problems › water in oil
water in oil
Go to page Previous  1, 2
MrrNoName
PostPosted: Sun Jan 23, 2011 8:26 am Up
MrBSI wrote:
206racer wrote:
it gets a service every year about march time.when it goes ill get them to check it over.
What engine is it?
72K miles is getting very near timing belt replacement if its a TU petrol lump Wink
indeed. wouldnt worry about it before your drive next week Razz definitely something to bear in mind though
206racer
PostPosted: Sun Jan 23, 2011 8:30 am Up
Its a 1.1 on a 51 plate which is why she only uses it for short journeys but we have been on holiday in it before saves alot on fuel.
hello
MrrNoName
PostPosted: Sun Jan 23, 2011 8:32 am Up
yeh, should look into getting the cam belt changed soon. if it snaps say bye bye to your engine Very Happy
EDIT: having said that its still fine to use untill you get it done
Get the timing belt replaced at the next service for piece of mind Wink
206racer
PostPosted: Sun Jan 23, 2011 8:34 am Up
Think book says 80000 miles dont know if it would be worth doing or buying another car.Any idea how much it roughly costs?
hello
PostPosted: Sun Jan 23, 2011 8:36 am Up
Timing belt is dead cheap for that engine Cool
1 hours labour plus the cost of the belt, there that simple to do on a 1.1 Wink
Its every 80K miles OR 5 years whichever comes 1st Wink
A Peugeot main dealer can change a 8 valve TU timing belt on a 206 in under 45 minutes Wink
206racer
PostPosted: Sun Jan 23, 2011 8:40 am Up
Thanks ill let them change it when it gets a service.
hello
206racer
PostPosted: Sun Feb 06, 2011 3:48 am Up
Lost a bit of coolant and still getting mayo colour under filler cap.Mate did a test where you suck coolant out into a tube filled with blue liquid and if the liquid changed to orange there is a leak on head gasket.Result was the liquid stayed the same colour.Are these tests reliable?Also the car is going to be serviced and have the timing belt and water pump done next week should i wait until i know for sure the head gasket is not leaking.Any advice.?
hello
MrrNoName
PostPosted: Sun Feb 06, 2011 5:04 am Up
those tests are pretty gd, if there are exhaust gasses in the coolant (signs of HG failure) the liquid will change colour, the fact that it stayed the same is just another sign thats the cars fine Smile
a bit of water loss is not uncomon considering age and mileage.
Page 2 of 2
