Online Now [1066]:
Visitors: 1065
Today: 144874
Total: 151632465
Forums › The Car › 206 Talk › oil sump plug size
oil sump plug size
Forum Index › 206 Talk
Shepy87
PostPosted: Mon Jan 24, 2011 2:12 pm Up
Could someone tell me the size of socket needed to remove the sump plug from a 2004 1.1, ive heard a few different things so could someone please confirm the correct size.
PostPosted: Mon Jan 24, 2011 2:16 pm Up
My 03 plate uses a square key.
Some have a normal hex.
Lay along the driver side front wheel with a torch stick you head under the car & have a look Wink
PostPosted: Mon Jan 24, 2011 2:34 pm Up
21/22mm socket I think
eddrj
PostPosted: Mon Jan 24, 2011 3:33 pm Up
21 mm
Old car 2000/ 206 2.0 hdi.
RichardEke
PostPosted: Tue Jan 29, 2013 5:04 pm Up
Me and a friend changed the oil in my car (2002 Peugeot 206 1.1L look) and it was a 24mm nut but it looked like there could be a square nut as well but a socket set was to hand so we used that.
It took about 3L that was without taking and emptying the oil filter out i say this cause we put far to much in and had to drain it out, doh
Life would be easier with universal jointed arms and fingers sometimes
