Latest: DanDan17
Overall: 17128
Online Now [71]:
Visitors: 70
Today: 13600
Total: 100574305
Forums › The Car › 206 Talk › Difference between auxiallary belt and cam belt
PostPosted: Tue Jan 25, 2011 11:09 am Up
Does anyone know what the difference is as per title? Had my aux belt replaced in Sep 09 and a guy I spoke too today reckoned the aux belt and cam belt is the same thing
PostPosted: Tue Jan 25, 2011 11:12 am Up
they are different belt
aux belt is for AC, alternator.
cam belt/ timing belt is to drive the engine Laughing
PostPosted: Tue Jan 25, 2011 11:13 am Up
Cam belt does timing
Aux belt does alternator, a/c, pas
wull
PostPosted: Tue Jan 25, 2011 11:17 am Up
as above,the auxillary belt is driven off the engine aswell but it goes to the alternator,a/c and pas.
the sole purpose of the cam belt is for the timing,and it's crucial that it's spot on.thats why it's a bigger job to do.you have to set the inlet and ex cams to a certain position so that the valves open and close at the right time,last thing you want is the pistons bending a valve.
2000 gti
Spanerman
PostPosted: Tue Jan 25, 2011 11:23 am Up
The cam belt also drives the water pump normally Smile
Sam.
Hello
PostPosted: Tue Jan 25, 2011 11:26 am Up
cheers guys, was hoping for it to be the cam belt and save me £300 lol
PostPosted: Tue Jan 25, 2011 11:47 am Up
MattyP wrote:
a gay I spoke too today reckoned the aux belt and cam belt is the same thing
Never, ever speak to him again.
Antix
PostPosted: Tue Jan 25, 2011 11:52 am Up
Custom - Red Stars
kieron
PostPosted: Tue Jan 25, 2011 12:28 pm Up
Antix wrote:
think he is a little bent lol
