Posted: Wed Jan 26, 2011 8:29 am |
Every day I have to top up the engine coolant, it is completely empty in the morning and evenings, when I open the cap the seems to be a large release of presure, any ideas??!
Posted: Wed Jan 26, 2011 8:32 am |
Leaking radiator or hose? Head gasket gone? Wet footwells?
Posted: Wed Jan 26, 2011 8:39 am |
If there's a big release of pressure... head gasket likely. Check for gunk in the coolant tank and mayo-like slime on the oil cap/dip stick.
| Moonstone GTI . . . SP grilles, ss cat-back, quick shift, ECU re-map. Trying to resist the modding bug this time and failing!
Z4 3.0si, 06 | |
Posted: Wed Jan 26, 2011 8:41 am |
Had the head gasket looked at and apparantly that is ok, no water in the footwell. The leak seems to be coming from the front drivers side of the car. There is no gunk on the oil dip stick or cap.
Cheers for your replies.
Posted: Wed Jan 26, 2011 8:44 am |
sounds like a hose as split on the underside of the coolant tank or a crack in the tank it self
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Wed Jan 26, 2011 8:46 am |
Ah that's good news. Does it seem to leak when the engine has cooled down? As it sounds like it's your water pump - it can hold water when driving in some cases so you don't get overheating as the seals are expanded. But when the engine cools the seals if damaged shrink and you lose water over night or parked during the day. Put some newspaper under your car and you'll be able to tell exactly where it's dripping from.
Z4 3.0si, 06 | |
Posted: Wed Jan 26, 2011 8:49 am |
I must admit at first I thought it was the head gasket, was v relieved when told is wasn't!
It does leak when it's cooled down, it leaks a bit when it's running but seems to leak more when the car is parked up during evening/day.
Good idea to put some paper down, just got to wait for a dry day to do so!
Posted: Wed Jan 26, 2011 8:53 am |
Good luck with it. Does sound like a dying water pump though - esp as you say you can locate the leak to the drivers side of the engine bay. But hopefully it's just a simple hose .
Z4 3.0si, 06 | |
