Posted: Thu Jan 27, 2011 4:46 pm |
is that easy to do?
would like to replace the bearings before i put them on.
any DIY guide?
Posted: Thu Jan 27, 2011 5:35 pm |
as in rear arm bearings or wheel bearings?
| If in doubt, drop a cog and put your foot down | |
Posted: Thu Jan 27, 2011 5:36 pm |
arm bearings
Posted: Thu Jan 27, 2011 5:47 pm |
just trying to make sense here, is the axle fitted to a car at the moment??
because in my experience it makes no difference as the bearings are inside it, to be honest i'd rather do it on the car then ride etc can be sorted easier because you will have checked the height before disassembly
Posted: Thu Jan 27, 2011 5:49 pm |
SDK206 wrote: |
because in my experience it makes no difference as the bearings are inside it, to be honest i'd rather do it on the car then ride etc can be sorted easier because you will have checked the height before disassembly |
no, looking for a disc axle atm, once i got it i will replace all the bearing and bushes before i put the axle on.
and i will have to swap the anti-roll bar, torsion bar and dampers as well
Posted: Thu Jan 27, 2011 5:52 pm |
right ok so you want to do bearings before you put new axle on yeah?
as i said might easier putting it on first because if the arms are tight to off it could be pain
Posted: Thu Jan 27, 2011 5:59 pm |
any special tools require?
Posted: Thu Jan 27, 2011 7:30 pm |
Bearing puller if you intend to do them rather than ask local garage just to press in and out and a large sledge hammer if axle siezed other than that you should be ok
