Latest: heikkisj
Overall: 17126
Online Now [56]:
Visitors: 55
Today: 15645
Total: 100299570
Forums › The Car › 206 Problems › axle refurbished
axle refurbished
PostPosted: Thu Jan 27, 2011 4:46 pm Up
is that easy to do?
would like to replace the bearings before i put them on.
any DIY guide?
SDK206
PostPosted: Thu Jan 27, 2011 5:35 pm Up
as in rear arm bearings or wheel bearings?
If in doubt, drop a cog and put your foot down Smile
PostPosted: Thu Jan 27, 2011 5:36 pm Up
arm bearings
SDK206
PostPosted: Thu Jan 27, 2011 5:47 pm Up
just trying to make sense here, is the axle fitted to a car at the moment??
because in my experience it makes no difference as the bearings are inside it, to be honest i'd rather do it on the car then ride etc can be sorted easier because you will have checked the height before disassembly Smile
PostPosted: Thu Jan 27, 2011 5:49 pm Up
no, looking for a disc axle atm, once i got it i will replace all the bearing and bushes before i put the axle on.
and i will have to swap the anti-roll bar, torsion bar and dampers as well Laughing
SDK206
PostPosted: Thu Jan 27, 2011 5:52 pm Up
right ok so you want to do bearings before you put new axle on yeah?
as i said might easier putting it on first because if the arms are tight to off it could be pain Smile
PostPosted: Thu Jan 27, 2011 5:59 pm Up
any special tools require?
MFACTOR001
PostPosted: Thu Jan 27, 2011 7:30 pm Up
Bearing puller if you intend to do them rather than ask local garage just to press in and out and a large sledge hammer if axle siezed other than that you should be ok
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
I make no appolagies for spelling punctuation
