Posted: Fri Jan 28, 2011 11:08 am |
Hi i just fitted tuning box and engine light wont go off even when ive put back other old connector in any ideas ? taken box off still light on
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Fri Jan 28, 2011 11:19 am |
probably something else, maybe the extra power from the box caused something to go?
Posted: Fri Jan 28, 2011 11:21 am |
It says about this in the manual that you get with the tuning box, it should give you a warning!
It is the 'anti-pollution fault', its due to the new readings that the ecu has to learn thru the increased fueling. It should go off after a week or so of driving. You could try connecting the tuning box, and disconnecting the battery to reset the ECU to default, to see if that makes it go off any quicker.
Posted: Fri Jan 28, 2011 11:29 am |
Not a solution... but have you noticed much difference in the power? cheers
the orange light is the engine mangement though isnt it ? so you r saying its safe to drive you think ?
Posted: Fri Jan 28, 2011 11:31 am |
Yes its safe to drive
Posted: Fri Jan 28, 2011 12:00 pm |
ok isnt is fail mot engine light on ??
Posted: Fri Jan 28, 2011 12:02 pm |
yes
Posted: Fri Jan 28, 2011 12:03 pm |
put a bit of tape over it
Posted: Fri Jan 28, 2011 12:06 pm |
Really?
Mines gone thru 2 MOTs with the light on before
and the rents has gone thru about 10 with the light on
Posted: Fri Jan 28, 2011 12:12 pm |
engine management light can go through depending on why its on ,i think, dont quote
| Originate, don't duplicate. | |
Posted: Fri Jan 28, 2011 12:13 pm |
eddrj wrote: |
ok isnt is fail mot engine light on ?? |
Nope, not unless it fails the emissions test.
Posted: Fri Jan 28, 2011 12:19 pm |
ok thats alrit then long as dont fail mot , tell you what well happy with it really is like another car much faster and more fun to drive ,not fussed about light as drives good and quick and wont fail mot
Posted: Fri Jan 28, 2011 12:20 pm |
eddrj wrote: |
ok thats alrit then long as dont fail mot |
It WILL fail next year as the mot test is changing slightly & becoming a lot more tougher
Posted: Fri Jan 28, 2011 12:23 pm |
fitted box again now because light on no matter what now , mot not due till about june but how would i get it off then took box off light still on same so may aswell use it now but really cant get that light off
