Posted: Fri Jan 28, 2011 12:04 pm |
Posted: Fri Jan 28, 2011 12:05 pm |
no i think its for abs as I had one in my old XS and thats what I got told.
edit: actually the one in the first pics looks like a h7 one, the second pic isnt
Posted: Fri Jan 28, 2011 12:06 pm |
Grey 3 pin connector is for crystal.
What year is your 206 as the installation method depends on the electrical system.
Posted: Fri Jan 28, 2011 12:07 pm |
DJ- wrote: |
no i think its for abs |
The ABS is on the passenger side of the car, 1st picture shows the drivers side as the washer bottle filler tube is pictured
MrBSI wrote: |
DJ- wrote: |
The ABS is on the passenger side of the car, 1st picture shows the drivers side as the washer bottle filler tube is pictured  |
im on about the second pic?
Posted: Fri Jan 28, 2011 12:11 pm |
Far to small for an abs connector.
Posted: Fri Jan 28, 2011 12:13 pm |
hey im just saying what I got told.
Posted: Fri Jan 28, 2011 12:14 pm |
MrBSI wrote: |
What year is your 206 as the installation method depends on the electrical system. |
X reg (2000) 1.4lx auto
Posted: Fri Jan 28, 2011 12:16 pm |
Any numbers on the wires in the second pic?
Get yourself a stalk from a non-plexed 206 with crystals fitted as standard and the Crystals will just be plug and play and work properly
Posted: Fri Jan 28, 2011 12:25 pm |
Lee wrote: |
Get yourself a stalk from a non-plexed 206 with crystals fitted as standard and the Crystals will just be plug and play and work properly  |
no numbers i can that i can see without delving down further.
im sure my 206 is non-plexed, do you mean get a stalk from a plexed ?
Posted: Fri Jan 28, 2011 12:27 pm |
No you need one from a non-plexed 206, plexed don't use stalks.
GTi, GT & RG were fitted with crystals, i think
Posted: Fri Jan 28, 2011 12:40 pm |
Lee wrote: |
GTi, GT & RG were fitted with crystals, i think |
im getting confused now sorry
my car is pre-plexed , is this the same as non-plexed ?.
the lights already on are H4 line type glass.
Posted: Fri Jan 28, 2011 12:42 pm |
Yes you car is preplexed/nonplexed same thing.
Basically Lee is saying, find a preplexed (pre oct 2001 i think) 206 that has crystal lights as standard and take the stalk adapter for the lights from that car.
As mentioned, early GTi's, XSi's, GT and RG i guess have them.
Posted: Fri Jan 28, 2011 12:43 pm |
Fit the crystal headlights.
Also change your original headlamp switch for one from an early 206 that had factory fitted crystals.
That's all there is to it
Posted: Fri Jan 28, 2011 12:51 pm |
i think i get it now.
i was getting confused about the non-pexed switch , even though mine is non-plexed, i would still need another non-plexed from a 206 fitted with crystals as standard around year 2000 gti xsi gt rg models.
plenty of switches on flea bay , if anyone could give me a link to the exact one, that would be great.
thanks for the help guys
