Online Now [538]:
Visitors: 537
Today: 184125
Total: 155476735
Forums › The Car › 206 Problems › NSF & OSF Lower Suspension Arms
Mitch
PostPosted: Fri Jan 28, 2011 1:40 pm Up
Just wondering if these are easy enough to take off and fit new ones?
Both are worn.... and need replacing.
Cheers!
paulrushton
PostPosted: Fri Jan 28, 2011 2:12 pm Up
I think there's a guide on Herr on how to do them.
Peugeot 206 GTI HDI Black
chunkielad
PostPosted: Sat Jan 29, 2011 8:54 am Up
There is - you might need a torx socket to undo the nuts - depends if someone changed them and you might as well do the drop links while you are there Wink
I did them and I ain't got a clue with mechanics!
If you do not try you will NEVER succeed!
