Latest: flipflap
Overall: 17140
Online Now [102]:
Visitors: 101
Today: 12975
Total: 113760553
Forums › The Car › 206 Problems › Removing front seat -
marone
PostPosted: Sat Jan 29, 2011 6:28 am Up
Hi all
I'm attempting to remove my front passenger seat but I've hit a little problem.
Under the seat there is a green clip which looks like it holds the wiring for the airbag. How on earth do you get this clip off?
Cheers
Phil
Current: 206 GTi 180 2.0l
Previous: 206 XSi 1.6l
PostPosted: Sat Jan 29, 2011 6:39 am Up
Very gently as the securing clips break easily Laughing
They are a tight fit for a reason Wink
marone
PostPosted: Sat Jan 29, 2011 7:07 am Up
Yep just like everything else on the car! Very Happy
Managed to do it in the end. Not sure if it was correct but i did this:
Lifted the red clipy thing at the top of the green plug and 'gently' pushed on the latch on the other side whilst pulling on the plug from the front. Came off easily in the end, but i guess its always easy when you know how.
Right now i need to figure out how to fix this damd seat!
Cheers
marone
PostPosted: Sat Jan 29, 2011 2:06 pm Up
Right so now i'm trying to dismantle the seat to figure out whats wrong with the mechanism and see if its fixable.
However i've been stopped in my tracks again. I can't get the back plastic cover off the seat. I can see its held on with a plastic latch towards the bottom corners but i cant get it to move enough to unlatch it.
Has anyone had any experience dismantling a 180 seat? If so how did you do it?
Ta.
