Online Now [341]:
Visitors: 340
Today: 27039
Total: 155897984
Forums › The Car › 206 Problems › Popping sound when front door open
Niallbg360
PostPosted: Sat Jan 29, 2011 6:19 am Up
just noticed a popping noise from the middle arm of the door as it opens fully i think it some sort of device to stop the door opening/closing fully can post a pic if u need.
just wondered if any one else had this problem and can it be resolved cheeply and quickly as its getting abit annoying
cheers
Ash
PostPosted: Sat Jan 29, 2011 6:20 am Up
Put some grease on it.
Edit: And it's called a Check Strap I *think*
Grease the check strap, that's the silver metal thing in the door shut between the hinges Wink
eddrj
PostPosted: Sat Jan 29, 2011 6:21 am Up
it will probably be door check strap there £22 ebay new or first try grease it up
Old car 2000/ 206 2.0 hdi.
smccullie
PostPosted: Sat Jan 29, 2011 6:47 am Up
check that the bolts are not loose, mine were all i had to do was tighten them
206 1.4 t reg
Niallbg360
PostPosted: Sat Jan 29, 2011 9:54 am Up
its all grease up but i can see on the check strap where the greese has been removed due to it rubbing ill check the blots with its lighting tomorrow.
cheers guys
