Latest: heikkisj
Overall: 17126
Online Now [253]:
Visitors: 252
Today: 26308
Total: 100359264
Forums › The Car › 206 Problems › Smell of petrol inside the car ???
icemonkey-2009
PostPosted: Sat Jan 29, 2011 5:09 am Up
Has anyone elso had this problem ???
A.S.MILLINGTON
Antix
PostPosted: Sat Jan 29, 2011 5:21 am Up
Custom - Red Stars
I <3 the smell of petrol
Sounds like a fuel leak tbh. Check your pipes [or get a friend to do it if you are nervous] Very Happy
icemonkey-2009
PostPosted: Sat Jan 29, 2011 5:28 am Up
ok thanks lol,
A.S.MILLINGTON
stevedude
PostPosted: Sat Jan 29, 2011 5:48 am Up
ive had this on 306
simple one to fix, if its same problem
let fuel tank go very low on fuel,
lift back seat.
lift black rubber cap
that is where the fuel tank is, also where the fuel pump and gauge is, if its wet, thats where ya problem is, IF its dry, cover it back up and look else where!
if you unscrew the huge nut, the plastic thing with fuel pump and gauge will lift out, carefull it'll be covered in fuel, NO SMOKING.
there is a large black rubber seal that should be around the plastic thing that holds the pump,
this might have slipped half way down the plastic case, so fuel now escapes. all ya do, is either go buy new one from pug "advised" or just pull seal up to the top of the case making sure its a snug fit, then lower it all back into tank, making sure its a good seal, then grab that huge nut, and do her up. jobs a good un
Happydays
icemonkey-2009
PostPosted: Sat Jan 29, 2011 6:43 am Up
Do u think i can do it myself ? or will i have to pay somone ? thanks Razz
A.S.MILLINGTON
00budham00
PostPosted: Sat Jan 29, 2011 6:48 am Up
Are you sure it was coming in the car, and you not stepped in a puddle or anything.
Does sound like little fuel leak.
stevedude
PostPosted: Sat Jan 29, 2011 7:19 am Up
do it ya self dude, its easy, just see if its wet or not!!
Happydays
Keebs
PostPosted: Sun Jan 30, 2011 11:49 am Up
I had this problem, it was the engine end fuel line clip, had to replace a section of fuel line
Keebs GLX
