Online Now [234]:
Visitors: 233
Today: 42583
Total: 117606173
Forums › The Car › 206 Problems › Main beam reflectors HELP
egouder
PostPosted: Sat Jan 29, 2011 7:27 am Up
Yesterday I started the car and when i put on the lights one was normal heading straight and the other one was pointing to the road directly below...i tried using the setting but it seems that the left reflector is stuck or something like that because the light wont go high enough.
Please help!! thanks
TTnTT
PostPosted: Sat Jan 29, 2011 8:31 am Up
Somehow accidently deleted what i put... Confused
PostPosted: Sat Jan 29, 2011 8:33 am Up
More likely the bulb is faulty or its come loose Wink
meady
PostPosted: Sat Jan 29, 2011 8:47 am Up
Trade Rating: +45
Have u changed thw bulb recently. If so have u put the bulb bk the right way
TEAM - I HATE FACEBOOK Smile
egouder
PostPosted: Sat Jan 29, 2011 9:45 am Up
i havent changed the bulbs... i dont know how either Confused if someone cn show me i would b grateful.
TTnTT were is this white hexagon on the light exactly?? do i have to get the light out or what?
thanks
egouder
PostPosted: Sat Jan 29, 2011 11:19 am Up
UPDATE: Very Happy
thanks a million!!! It totally worked!! with some patience and tinkering, because the mechanism was not pulling the bulb enough neither manually, so had to use a long nose and mork my way to pull it manually!! Smile
btw: Is it normal to have the driver's side head light a little more dipped than the other in order for other drivers not to be bothered??
thanks
