Latest: ArtistKS
Overall: 17145
Online Now [71]:
Visitors: 70
Today: 23103
Total: 115922848
Forums › The Car › 206 Problems › Right Side Repeater / Indicator Flashing Too Fast!
adzar
PostPosted: Sun Jan 30, 2011 9:03 am Up
As title really - the right side repeater is flashing about twice as fast as it should. The left side repeater is working fine as are all the other electronics in the car. It's an 05 1.4 sport.
I recently changed the headunit, but it only occured about the second time I used the car after doing that. I've done a BSi soft reboot, but that didn't solve it.
Any help would be greatly appreciated.
1.4 Sport
eddrj
PostPosted: Sun Jan 30, 2011 9:07 am Up
that usually happens when a bulb has gone
have you checked the bulbs ?
Old car 2000/ 206 2.0 hdi.
stevedude
PostPosted: Sun Jan 30, 2011 9:10 am Up
as above!
Happydays
Matt
PostPosted: Sun Jan 30, 2011 9:19 am Up
Trade Rating: +32
a blown bulb somewhere in the indication systemm has blown.
put your hazards on and have a walk around the car Smile
drunknmunky
PostPosted: Sun Jan 30, 2011 9:23 am Up
or the connection could have come loose mine did this after putting new lights in once and i found i had not put the connector in fully so check the connections for them
adzar
PostPosted: Sun Jan 30, 2011 9:44 am Up
Spot on - it was the rear right hand bulb! Thanks!
So is this supposed to happen so that you know when a bulb has gone?
I looked for a 'how to' for taking out the rear light to change it, but couldnt find one. Can anyone point me in the right direction?
1.4 Sport
PostPosted: Sun Jan 30, 2011 9:45 am Up
Yes, cars have been doing that since before you where born Wink
Matt
PostPosted: Sun Jan 30, 2011 9:49 am Up
Trade Rating: +32
open boot, look right, pull side carpet back. should see a black plastic wing nut type thing. unscrew it. pull light forward slowly untill you see the plug. locate the tab, push the tab in while pulling the whole plug out Smile
eddrj
PostPosted: Sun Jan 30, 2011 9:51 am Up
there used to be a how to... on this must of been moved ,
as above is easy.
adzar
PostPosted: Sun Jan 30, 2011 9:59 am Up
Thanks for all the help!
1.4 Sport
adzar
PostPosted: Fri Feb 11, 2011 11:27 am Up
Peugeot and halfrauds both told me I needed an amber bulb, but my car needed the clear bulb with the knobs at opposite sides.
Weird.
1.4 Sport
PostPosted: Fri Feb 11, 2011 11:34 am Up
Both amber and clear would have worked.
adzar
PostPosted: Sat Feb 12, 2011 10:41 am Up
No the amber didn't fit, because the two little knobs are in the wrong place. They had to be at opposite sides as they are on the clear bulb.
1.4 Sport
PostPosted: Sat Feb 12, 2011 10:44 am Up
You can get amber bulbs in different fitments if you know where to look Wink
Supreno
PostPosted: Thu Nov 20, 2014 1:26 pm Up
HI guys I hope someone here can help. my wife drives a 206hdi which had a rear indicator out, I replaced the bulb and all bulbs are now working fine however the left side of the car flashes twice as quickly as the right..Yes I know it only flashes quickly if the current is out by a faulty bulb/ bad connection, however I have checked all connections and as the bulbs are all working I'm stumped..... Hoping you can help???? Thanks in advance...
