Latest: dreyfalon
Overall: 17121
Online Now [447]:
Visitors: 445
Members: 1
Today: 59220
Total: 97359225
Forums › The Car › 206 Problems › Head Gasket
Head Gasket
Neilatkins
PostPosted: Mon Jan 31, 2011 8:25 am Up
My diesel 206 is leaking coolant, I've had the fan & water pump replaced & it's made no difference, also had car checked for leaking pipes, is it definately likely to be the head gasket? Also what would a reasonable price be to have this fixed at a garage?
Cheers
Thanks Neil
giveitsomebar
PostPosted: Mon Jan 31, 2011 8:37 am Up
worth checking the heater matrix aswell if you havent done this already
Neilatkins
PostPosted: Mon Jan 31, 2011 8:39 am Up
Cheers, there is no water coming into the passenger footwell, does this rule it out or not?
Thing that confuses me is no gunk in oil tank or white smoke anywhere!
Thanks Neil
giveitsomebar
PostPosted: Mon Jan 31, 2011 8:43 am Up
im not 100% but i think if the matrix has gone it will come into the footwell
your best bet will be get it up on axle stands fill it up with water and leave it running till the thermostat opens and then you at least will have an idea where its coming from
Cheers
