Posted: Mon Jan 31, 2011 7:25 am |
My diesel 206 is leaking coolant, I've had the fan & water pump replaced & it's made no difference, also had car checked for leaking pipes, is it definately likely to be the head gasket? Also what would a reasonable price be to have this fixed at a garage?
Cheers
Posted: Mon Jan 31, 2011 7:37 am |
worth checking the heater matrix aswell if you havent done this already
Posted: Mon Jan 31, 2011 7:39 am |
Cheers, there is no water coming into the passenger footwell, does this rule it out or not?
Thing that confuses me is no gunk in oil tank or white smoke anywhere!
Posted: Mon Jan 31, 2011 7:43 am |
im not 100% but i think if the matrix has gone it will come into the footwell
your best bet will be get it up on axle stands fill it up with water and leave it running till the thermostat opens and then you at least will have an idea where its coming from
Cheers
