Latest: Mr-Koekwaus
Overall: 17125
Online Now [121]:
Visitors: 120
Today: 35578
Total: 99420742
Forums › The Car › 206 Problems › Lighting problems
Lighting problems
Lewis
PostPosted: Tue Feb 01, 2011 7:41 am Up
Hi guys, so as you might know just got a 180 Smile
I have a couple of problems that i wouldnt mind sorting, the side lights dont appear to be working, it was only when i braked hard last night they popped on that i noticed they hadnt been on whilst i was driving! they have again gone off now.
Another problem is the buttons around the climate control do not illuminate all the time, they are also intermittant!
If anyone has had these problems please shine some light on the situation Smile
Thank you, Lewis.
Tivoli LX 1.1
Black GTI 180
White VXR Burg
giveitsomebar
PostPosted: Tue Feb 01, 2011 8:09 am Up
its worth going over all the lights to make sure the connectors are on properly and it sounds like its a bad earth but i dont know earth spots on a 180
Lewis
PostPosted: Tue Feb 01, 2011 1:19 pm Up
anyone else...
Tivoli LX 1.1
Black GTI 180
White VXR Burg
-RAJ-
PostPosted: Sat Feb 19, 2011 8:48 pm Up
i have the same thing with my climate control, have to bang it for them to come on. did you manage to get to the bottom of this?
Harty
PostPosted: Sun Feb 20, 2011 4:44 am Up
my climate control had this, just changed the bulbs and the problem never came back, might be a broken connector in the bulb itself and when you brake/bang on it it connects for a bit.. climate control bulbs are easy to change, its the normal A/C thats the pain
hope that helps
Chris
Harty
-RAJ-
PostPosted: Sun Feb 20, 2011 6:20 pm Up
yh i have the non digital cc/ac so its a reall pain to get to the bulbs. there's deffo a lose connection between the bulbs me thinks, ill check it out cheers
Harty
PostPosted: Mon Feb 21, 2011 1:31 am Up
if its non digital one then good luck..... i ripped my thumb taking out one of the adjuster rods... quite sore took me about an hour to change all the bulbs and manoeuvre the rods back into place... 2 of them bent but still work ok Razz
good luck
Chris
Harty
