Online Now [410]:
Visitors: 409
Today: 64194
Total: 156779511
Forums › The Car › 206 Problems › Rear wiper blade removal
delta9
PostPosted: Tue Feb 01, 2011 12:04 pm Up
Hi,
I have a 2001 206 GTI and am struggling to remove the rear wiper blade
The guides on the net don't seem to be much help
Any tips would be really appreciated
UK
Ash
PostPosted: Tue Feb 01, 2011 12:30 pm Up
Erm... The blade? Or the whole assembly?
dopey
PostPosted: Tue Feb 01, 2011 12:33 pm Up
in the middle of the wiper blade underneath you will see it clips in just unclip it =]
dont try to take it off at the beginning as that is the main arm, break that you wont have a rear wiper.
delta9
PostPosted: Tue Feb 01, 2011 12:45 pm Up
thats the trouble, i cant find any clip, it all looks like a solid block
there are some little holes in this block, should i put a screwdriver in them to unclip it or something
UK
PostPosted: Tue Feb 01, 2011 12:48 pm Up
Blade goes down and the arm comes upwards. Should just pop off Confused
delta9
PostPosted: Tue Feb 01, 2011 12:51 pm Up
here are some images, the blade wont just pop off no matter what i try
UK
PostPosted: Tue Feb 01, 2011 2:02 pm Up
Just pull the blade away from the the arm on the car.
delta9
PostPosted: Wed Feb 02, 2011 11:56 am Up
it wont just pull off, and there is no clips anywhere at all
tried again today with a screwdriver prodding it etc but it wont come apart, guess ill take it down the peugeot garage on the weekend and get them to take it off instead
i think the weird attaching block is whats causing the problem, the front is dead easy to change but the back is just weird
UK
PostPosted: Wed Feb 02, 2011 12:00 pm Up
Man up and pull it off, comes off easy.
