Posted: Wed Feb 02, 2011 5:10 am |
Hi guys
1. Please help me, i keep getting water under my passenger seat of 206, its not antifreeze and heater matrix is fine, i only get water when it rains and that too under passenger seat, but is it possible to figure out, where the water is coming from, i have checked and there are no visible leaks or any water that i can see dripping, but the carpet is always wet when it rains
2. i have also recently changed the spring around shock absorber on front left side, since its been changed i keep getting this wobbly feeling when i accelrate and turn right, could it be the case because 1 spring is new and other is old, steering wheel also feels tight and i tries to stay in centre postion for example when i turn left or right the steering while has the tendency to turn itself to centre very quickly
please help me guys,
| i am really good at nothing | |
Posted: Wed Feb 02, 2011 5:12 am |
Check the window seals.
Have a friend use a hose on the car while you sit in the car & check for leaks.
Posted: Wed Feb 02, 2011 7:02 am |
Hi CD-vRS
i have tried this solution as well, i cannot see any leaks coming in the car or any drips coming in, but after 4-5 minutes of using a hose(putting the water on) the carpets gets wet.
Posted: Wed Feb 02, 2011 11:19 am |
is the rubber seal around the door on properly?
Posted: Wed Feb 02, 2011 11:25 am |
door seal as above?
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Wed Feb 02, 2011 11:44 am |
Rubber door seals
Window seals
Roof aerial
The insulation behind the doorcard, came unstuck or got a hole in
Heater matrix leaking.
Posted: Fri Feb 04, 2011 5:52 am |
Hi,
Not sure if this is applicable to 206's but I used to have a Ford Escort which started leaking inside. I changed all the rubber linings but it didnt stop. Eventually I realised it was the insulating sheets iside the door panels that I had cut to retrofit central locking and electric windows. Didnt realise that this insulation also prevents rain water getting into the car. Once this was changed it stopped leaking.
Posted: Fri Feb 04, 2011 6:32 am |
I had same problem on a Ford Cortina, but it was only getting wet when I drove anywhere. I got under the car and found the floorpan had come apart slightly and water was spraying up off the road and going into the seam. I tapped it back with a hammer and put some underseal on. Solved the problem. Don't know if any use but might help.
Posted: Fri Feb 04, 2011 8:06 am |
My guess is door membrane (behind the door cards).
Search the forum and there are several other posts about it. They either come unstuck or are damaged/removed when someone works on the car, fits speakers etc. You can re-stick them or make new ones yourself as they are not cheap to buy and are basically only a thick sheet of polythene.
