Posted: Wed Feb 02, 2011 3:36 pm |
Posted: Wed Feb 02, 2011 3:42 pm |
Top right in your picture is ICV
Top left is TB heater
Middle right is throttle position sensor
Bottom is inlet air temp sensor
Very bottom is manifold absolute pressure sensor (MAP)
| ICE goes in drinks. NOT in cars. | |
Posted: Wed Feb 02, 2011 3:51 pm |
Brilliant thanks
Posted: Wed Feb 02, 2011 3:55 pm |
pm'd about your angels
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Thu Feb 03, 2011 6:04 am |
I've seen cleaner coal mines!
Posted: Thu Feb 03, 2011 6:06 am |
Idle is a bit erattic so I'm going to give it a clean or even replace it with a spare I have at the weekend.
Posted: Thu Feb 03, 2011 6:17 am |
ive got spare ICV, MAP sensor and throttle position sensor if you run into any problems
