Online Now [249]:
Visitors: 248
Today: 174852
Total: 155467599
Forums › The Car › 206 Problems › very loud clickking
very loud clickking
black31
PostPosted: Thu Feb 03, 2011 7:39 pm Up
loud click when accelerating and when slowing down any ideas
m
-Dave-
PostPosted: Thu Feb 03, 2011 7:56 pm Up
Trade Rating: +36
Ice lolly stick in your wheel's.
Ex 206 Owner.
black31
PostPosted: Thu Feb 03, 2011 8:01 pm Up
only one click when decelerating an d one when acc
m
-Dave-
PostPosted: Thu Feb 03, 2011 9:08 pm Up
Trade Rating: +36
Is it coming from inside or outside the car?
Ex 206 Owner.
Salty_jon
PostPosted: Fri Feb 04, 2011 1:28 am Up
Sounds like it could be an engine mount or a badly worn cv joint
206 sold but can\'t wait to get another. Swaps for a Leon Cupra anyone?
giveitsomebar
PostPosted: Fri Feb 04, 2011 2:04 am Up
cv joint
black31
PostPosted: Fri Feb 04, 2011 7:54 am Up
looked at all mounts and jiggled also while on axel stands all seems ok ! not sure about cv joint as can set off drive along ok to any speed its only if you accell erate had .and you get athe clickonly once same withdec from any speed down ok is only when brake hard -click ...if cvs already driving should be no slack to take up and no click does this make sense ...engine mounts look ok but how many is there /as you look at it .. top left between two posts in compression should be ok !!!!!!..topright suspension from above /do these streatch or brake down in any way ?and botton rear enclosed in ring rubber looks ok but attatches to body with like a metal section and i think rubber insert any thoughts please
thanks in advance
m
black31
PostPosted: Fri Feb 04, 2011 8:02 am Up
its difficult to say wherits comin from really but its from front lower enginge compartment ish area that narrows it down .not
m
