Latest: dreyfalon
Overall: 17121
Online Now [42]:
Visitors: 41
Today: 8375
Total: 97756381
Forums › The Car › 206 Problems › Filling up with petrol
samreecestrange
PostPosted: Fri Feb 04, 2011 10:22 am Up
Went to full up the car and got a surprise when kept cutting out at only 53 quid. never filled it all the way up before so ignored it. Got back in the car andwas about 3/4s full.
So does anyone know why it wont take anymore?
Thanks for any help
Pugsy
PostPosted: Fri Feb 04, 2011 10:27 am Up
Just a guess but i'm thinking you may have a small leak somewhere Smile
Pugsy206asw
kieron
PostPosted: Fri Feb 04, 2011 10:30 am Up
dodgy fuel gauge they was a technical bulliten on some 206,s that was reading 3/4 when full and 1/4 when empty
if it clicked that means its full so must of had a dodgy fuel gauge
Account suspended
Liam-HuTcH
PostPosted: Fri Feb 04, 2011 10:33 am Up
East Area Rep - Liam-HuTcH
usually costs me £63 to fill mine up Sad
Team: Smashed Up Firedance
Team: Black 206
samreecestrange
PostPosted: Fri Feb 04, 2011 10:37 am Up
how I don't have a leak, was the dodgy fuel gauge a recall by peugeot or just a common issue. However mine definitely doesn't read a 1/4 when empty as ive run it much lower than that.
Signature removed due to size
PostPosted: Fri Feb 04, 2011 10:53 am Up
Just a dodgey fuel gauge, you get used to it.
My low fuel light comes on at 1/4 of a tank.
Aar_Im_A_Pirate
PostPosted: Fri Feb 04, 2011 11:13 am Up
Could be the nozzle at the petrol station, if you hit the side of the nozzle off the side then it thinks the car is full.
Team: Derv
PostPosted: Fri Feb 04, 2011 12:00 pm Up
If you can't get the normal amount in money wise, it must have been a fault with the nozzle you used at the petrol station.
samreecestrange
PostPosted: Fri Feb 04, 2011 2:16 pm Up
ok well, ill check for leaks anyway, and is there a way to change the fual gauge and make it correct.
It will annoy me big time
Iain
PostPosted: Fri Feb 04, 2011 3:35 pm Up
That's a full tank, so must be the fuel gauge surely
Our snow > Your snow
Ash
PostPosted: Sat Feb 05, 2011 6:37 am Up
How can you base a full tank on Money Value Confused Petrol Prices vary...
samreecestrange
PostPosted: Sat Feb 05, 2011 6:44 am Up
the petrol pump clicked out as it was full, but the gauge in teh car says 3/4 full
Ash
PostPosted: Sat Feb 05, 2011 6:50 am Up
It was directed more to the replies above.
samreecestrange
PostPosted: Sat Feb 05, 2011 6:56 am Up
oh right, i get confused very easily
smiddies
Normally when i fill up a full tank... i leave it a while after it first clicks off!! Seems to work normally I get another 5 litres or so!! But then I notice the price go up too Sad
