Posted: Fri Feb 04, 2011 12:49 pm |
just something i've wondered really since i got my car, can you manually add ESP/ASR to a 206 without it as standard? I know climate control can be but i'm guessing you would need the clocks, wiring, sensors, buttons and the ecu for it?
also can you manually install auto lights and wipers? guessing you would need the sensors, com 2000 unit for it and the ecu aswell?
Posted: Fri Feb 04, 2011 12:57 pm |
You could, but its waaaaaaaaaaaaay more trouble than its worth.
If your ECU and BSI don't have the capabilities, you are going to have to get the ECU virgiinsed and then custom coded to match a BSI from a 1.6hdi or a GTI180. Then you'll need the matching immobilser system as well.
Posted: Fri Feb 04, 2011 1:04 pm |
well mines is just a 2.0 hdi dturbo so i wouldnt think it had the capabilities good thing is its multiplex but can be a bad thing aswell for killing bsi but yeah my '04 gti 138 had esp and stuff just made me wonder... i regret selling it how about auto lights/wipers?
Chris
Posted: Fri Feb 04, 2011 1:13 pm |
For wipers i think it uses a different windscreen, not 100% without checking.
For lights, you'd need all the components then the ECU and BSI tweeking
Posted: Fri Feb 04, 2011 3:58 pm |
Trade Rating: +59
Most DTurdos' had auto lights and wipers as standard.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Feb 04, 2011 4:16 pm |
Lee wrote: |
For lights, you'd need all the components then the ECU and BSI tweeking |
same screen but were the rain/light sensor go,s onto the glass is different and so is the rear view mirror
Posted: Fri Feb 04, 2011 6:45 pm |
G. wrote: |
Most DTurdos' had auto lights and wipers as standard. |
Dunno then G mines is an 02 plate so must have just been later models. Mine has sport wings and bumpers but had manual mirrors :s
Posted: Mon May 02, 2011 4:20 am |
Auto lights and wipers as standard? mine must have been ill that day then. As above, sport everything else, but manual mirrors
