Latest: heikkisj
Overall: 17126
Online Now [73]:
Visitors: 72
Today: 19744
Total: 100256030
Forums › The Car › 206 Talk › pollen/cabin filter?
mrjonahlovetts
PostPosted: Sat Feb 05, 2011 3:28 am Up
does anyone know where it is on a 2l 2003 hdi because i think it needs changing
and is it expensive or even neccesary??
regards
jonah
mrjonahlovetts
NathanG
PostPosted: Sat Feb 05, 2011 3:40 am Up
Its under the drivers side windscreen. As you look in the engine bay, along the top left hand side, just under the screen. I have no idea if its necessary but im changing mine today, going to pop to Halfrauds to get it.
PostPosted: Sat Feb 05, 2011 3:44 am Up
They should be changed every year ideally.
sillyhilly
PostPosted: Sat Feb 05, 2011 3:45 am Up
If you get it off egay it's cheap as chips. Do it when you service the car, its always nice getting fresh, non-mould-spore air coming into the car Smile
shop.ebay.co.uk/i.html...m270.l1313
Hi Mikey Smile
eddrj
PostPosted: Sat Feb 05, 2011 3:46 am Up
should be changed same time as oil change , only about £7 and easy to change.
There is a how to ... on here on this .
Old car 2000/ 206 2.0 hdi.
mrjonahlovetts
PostPosted: Sat Feb 05, 2011 3:51 am Up
lol
mine hasnt been changed for 7 years!!
mrjonahlovetts
sillyhilly
Get it changed Wink
Hi Mikey Smile
PostPosted: Sat Feb 05, 2011 3:54 am Up
sillyhilly wrote:
Get it changed Wink
What He Said
Best to do on your service if you do it yourself, i shall be doing that on my days off next week
PostPosted: Sat Feb 05, 2011 4:18 am Up
They are visibly dirty after 12 months so after 7 years they'd be minging!
NathanG
PostPosted: Sat Feb 05, 2011 4:29 am Up
Ebay Pollen Filters
eddrj
PostPosted: Sat Feb 05, 2011 4:31 am Up
o dear 7 years lol,
i do mine every 5 months
mrjonahlovetts
PostPosted: Sat Feb 05, 2011 4:58 am Up
will post up a pic when i get it out Very Happy
mrjonahlovetts
