Latest: Mr-Koekwaus
Overall: 17125
Online Now [228]:
Visitors: 227
Today: 40800
Total: 100123528
Forums › The Car › 206 Problems › Where Does This Bolt Come From
NathanG
PostPosted: Sat Feb 05, 2011 6:41 am Up
Due to the savage knocking underneath/at the front of my car i decided to have a look this morning despite the absolute misery that is Welsh weather. Took the wheel off, had a browse and came across this laying quite happily on my wishbone. My question is where is it from and what does it do apart from rest on wishbones.
Mattie-RS
PostPosted: Sat Feb 05, 2011 7:05 am Up
isnt that what holds the driveshaft still on the passenger side
PugJH
PostPosted: Sat Feb 05, 2011 7:10 am Up
Sure its something like that, holds the joint to the arm :S
Pretty sure its important and shaped like that so it doesnt fall out.
Top bolt must have come loose and fell off or snapped
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Sat Feb 05, 2011 7:16 am Up
Well it's not the bolt that holds the hub onto the ball joint, not the hub to damper bolt, not the top mount bolts..not a brake caliper bolt...
What's the bolt that holds the driveshaft middle bearing into the engine mount look like?
mattievrs
PostPosted: Sat Feb 05, 2011 7:18 am Up
its the bolt that pulls and holds the drivers side driveshaft intermediate bearing in the housing
NO LONGER ACTIVE ON THE FORUM
NathanG
PostPosted: Sat Feb 05, 2011 7:26 am Up
Hmm important then. Would this cause the knocking.
PostPosted: Sat Feb 05, 2011 7:30 am Up
If that's where it lives you can just about see where it comes from on this picture...
It's just below the shaft bearing...
pat_986
PostPosted: Sat Feb 05, 2011 7:32 am Up
Yes, it will cause knocking, and will cause ware on the bearing while it's not fitted, I would get it back on quick.
cgi.ebay.co.uk/peugeot...1c14d3cc3e
They bolts are know as 'hockey sticks' apparently!
2004 Flamenco red GTi 180
NathanG
PostPosted: Sat Feb 05, 2011 7:49 am Up
Do you mean here
PostPosted: Sat Feb 05, 2011 7:51 am Up
Yes...
NathanG
PostPosted: Sat Feb 05, 2011 7:52 am Up
Thumbs Up Epic, cheers mate
That looks like the passengers side.
[EDIT] no it doesnt i'm a c**k
mattievrs
I believe there are 3 of them in total
