Posted: Sat Feb 05, 2011 7:41 am |
Due to the savage knocking underneath/at the front of my car i decided to have a look this morning despite the absolute misery that is Welsh weather. Took the wheel off, had a browse and came across this laying quite happily on my wishbone. My question is where is it from and what does it do apart from rest on wishbones.
![](http://i8.photobucket.com/albums/a26/krav/photo-4.jpg~original)
| | ![](images/spacer.gif) |
Posted: Sat Feb 05, 2011 8:05 am |
isnt that what holds the driveshaft still on the passenger side
| Renault Clio III RS - Race Car ![Cool Cool](images/smiles/icon_cool.gif)
Former Poverty 206 XS 1.6Turbo Owner ![Razz Razz](images/smiles/icon_razz.gif) | |
Posted: Sat Feb 05, 2011 8:10 am |
Sure its something like that, holds the joint to the arm :S
Pretty sure its important and shaped like that so it doesnt fall out.
Top bolt must have come loose and fell off or snapped
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Sat Feb 05, 2011 8:16 am |
Well it's not the bolt that holds the hub onto the ball joint, not the hub to damper bolt, not the top mount bolts..not a brake caliper bolt...
What's the bolt that holds the driveshaft middle bearing into the engine mount look like?
Posted: Sat Feb 05, 2011 8:18 am |
its the bolt that pulls and holds the drivers side driveshaft intermediate bearing in the housing
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sat Feb 05, 2011 8:26 am |
Hmm important then. Would this cause the knocking.
Posted: Sat Feb 05, 2011 8:30 am |
If that's where it lives you can just about see where it comes from on this picture...
It's just below the shaft bearing...
![](http://i38.photobucket.com/albums/e105/s1pso/20090314001.jpg~original)
Posted: Sat Feb 05, 2011 8:32 am |
Yes, it will cause knocking, and will cause ware on the bearing while it's not fitted, I would get it back on quick.
cgi.ebay.co.uk/peugeot...1c14d3cc3e
They bolts are know as 'hockey sticks' apparently!
| 2004 Flamenco red GTi 180 | |
Posted: Sat Feb 05, 2011 8:49 am |
Do you mean here
![](http://i8.photobucket.com/albums/a26/krav/20090314001-1.jpg~original)
Posted: Sat Feb 05, 2011 8:51 am |
Yes...
Posted: Sat Feb 05, 2011 8:52 am |
Epic, cheers mate
That looks like the passengers side.
[EDIT] no it doesnt i'm a c**k
I believe there are 3 of them in total
