Latest: DanDan17
Overall: 17128
Online Now [200]:
Visitors: 199
Today: 26463
Total: 100626866
Forums › The Car › 206 Problems › High Temperature Indication Advice Needed
roro
PostPosted: Sun Feb 06, 2011 1:30 am Up
Dears
I would like to have your assistance if possible ,
I have a Peugeot 206 sedan, Bought through France, 4 doors, 1587CC or 1.6 16V, Manual gear Box 5 gears, made 2009.
I have the following problem the temperature indicator suddenly goes to maximum and the alarm sounds and stop indicator is flashing, notes that:
- When sensing the radiator temperature is not hot
- The Temperature of the pipes going from and to the radiator is Ok
- The car was on for less than 5 minutes
- The coolant level is Ok
What I would like to ask you is :
- the location of the temperature senor
- what happens if I disconnect the temperature sensor if the car is off then turned it on , or if I disconnect the sensor while the car is running
- where is the location of the temperature sensor connector , what color does it have any number ?
- If I want to check the resistivity of the connector what should be the normal reading value
- what is the impact of driving the car with the faulty temperature connector
- what is the impact of driving the car with a disconnected temperature connector
Attached you will find a picture of my engine block
<a href="http://www.flickr.com/photos/59218335@N06/5420967970/" title="IMG_4971 by roro2013, on Flickr"><img src="http://farm6.static.flickr.com/5094/5420967970_979225e346.jpg" width="500" height="375" alt="IMG_4971" /></a>
Thank you
Roro
