Online Now [301]:
Visitors: 300
Today: 103679
Total: 155706696
Forums › The Car › Request a how-to › Changing the colour of the speedo lights.
Mowle5677
PostPosted: Sun Feb 06, 2011 12:10 pm Reply with quote Up
How do you change the colour of your speedo lights and does anyone have a website where I can buy the stuff?
Can't wait to take the car to it's first show Smile
PostPosted: Sun Feb 06, 2011 12:18 pm Reply with quote Up
what age is the car???
Mowle5677
PostPosted: Sun Feb 06, 2011 12:25 pm Reply with quote Up
2000
PostPosted: Sun Feb 06, 2011 12:31 pm Reply with quote Up
you can change the bulbs for somthing like these....
cgi.ebay.co.uk/10-X-CA...3387wt_989
or
cgi.ebay.co.uk/10-Blue...117wt_1139
but the dash has a orange filter so colour looks slightly off imo,
best way i found to change the colour was lockwood dial kit.
Jay794
PostPosted: Sun Feb 06, 2011 12:36 pm Reply with quote Up
Nick180 is doing mine at the moment as you have to solder new SMD LED's on the newer models, older ones are just twist and replace. The ones that NorthantsBen referred to will only work on older models
Mowle5677
PostPosted: Sun Feb 06, 2011 12:46 pm Reply with quote Up
Thanks buddy. Iv done the clock light which was a pain but I done want to take apart the speedo unit again as I mucked my old one up Sad
eddrj
anyone got any pics how them blue bulbs would look ?? if there off colour a bit .As dash has orange filter
Are lockwoods much better ??
Old car 2000/ 206 2.0 hdi.
PostPosted: Sun Feb 06, 2011 12:49 pm Reply with quote Up
i have tried both and the lockwood looked 100% better imo,
i fitted xeon white LED's behind the lockwoods to make them bright and crisp.
PostPosted: Sun Feb 06, 2011 12:51 pm Reply with quote Up
im 90% sure your 2000 model will be twist bulbs that are easy as pie to change, just need to remove the speedo surround, take out the screws that hold the unit inplace, pull it forward and twist out each bulb and put new one in.
eddrj
PostPosted: Sun Feb 06, 2011 12:52 pm Reply with quote Up
ok thanks
Mowle5677
Have you got a link to a lockwood kit?
PostPosted: Sun Feb 06, 2011 12:54 pm Reply with quote Up
ebay will have them Wink
to fit the lockwood kit you will need to take the speedo apart to fit.
changing just bulbs you just need to change the bulbs as long as yours is twist bulbs.
glenpring
PostPosted: Sun Feb 06, 2011 1:08 pm Reply with quote Up
I have some spair blue SMd LED's from when I did my clocks if anyone is intrested pm me I have 20 blue ones
Mowle5677
PostPosted: Sun Feb 06, 2011 5:17 pm Reply with quote Up
onHow did it turn out?
almir92
PostPosted: Sun Feb 06, 2011 5:48 pm Reply with quote Up
if you could supply pics when you do it you would be helping a lot (y)
  Quick Reply
Username:
Message:
Quote the last message
