Posted: Sun Feb 06, 2011 9:40 am |
The engine used to idle a bit high, and needed a tap on the throttle to get it started. I was told that the idle control valve needed replacing.
So I did and gave it a clean at the same time.
The idle wasn't nearly as bad as it was but it still had a 'surge' every minute or so.
So I changed the full throttle body, TB heater, throttle position sensor, air temp sensor & MAP sensor but it still has the occasional surge in revs.
The revs sometimes stick around 2k RPM but it's quite rare.
Any ideas on what else it could be?
Thanks.
Edit:
Here's a video.
s624.photobucket.com/a...EO0007.mp4
It cut out by itself at the end.
Posted: Sun Feb 06, 2011 12:07 pm |
Anyone?
Would like to get it sorted today really.
Posted: Sun Feb 06, 2011 1:07 pm |
temp sensor i have had that problem so many times ( euro car parts £25) i need 1 as well for mine.
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Sun Feb 06, 2011 1:15 pm |
Throttle cable sticking?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sun Feb 06, 2011 2:33 pm |
mattievrs wrote: |
Throttle cable sticking? |
Nope, it does it when on idle. And at random intervals.
Ed suggested that the intake manifold may have a leak. There is a bit of a hissing.
Posted: Sun Feb 06, 2011 2:46 pm |
leigh_boy wrote: |
temp sensor i have had that problem so many times ( euro car parts £25) i need 1 as well for mine. |
Already swapped it.
Posted: Sun Feb 06, 2011 4:27 pm |
the green plug 1?
other thing it could be and sorry for spelling is Throttle Potentiometers .
are you able to put it on diagnostics?
| *DEAD*206 Gti 138
Posted: Sun Feb 06, 2011 7:05 pm |
CD-vRS wrote: |
mattievrs wrote: |
Ed suggested that the intake manifold may have a leak. There is a bit of a hissing. |
i think youve answered your question mate.
Posted: Mon Feb 07, 2011 3:47 am |
i have this exact problem. and have done the exact same replacements. what sort of a job is removing the inlet manifold to check the gasket?
Posted: Mon Feb 07, 2011 4:13 am |
Kersh wrote: |
i have this exact problem. and have done the exact same replacements. what sort of a job is removing the inlet manifold to check the gasket? |
Not all that difficult. Removed the IM from the last 206 I had in for breaking.
I'm going to give it a go tomorrow night. I'll let you know how I get on.
Posted: Mon Feb 07, 2011 4:24 am |
perfect thanks! ill watch this one closely
Posted: Mon Feb 07, 2011 3:19 pm |
Was a bit of a pain but got there in the end.
Had to remove the throttle body, wiring housing, fuel rail & injectors.
This is from the 206 I'm breaking, decided to take it off the failed engine before playing with the good one.
I'll swap it to the one on the other 206 tomorrow night and see if that works, the seals look alright on this one.
On the far right in this picture is a tiny bit of silver hose,
You need to unclip it for the intake manifold to come off.
Took me about 45 mins to remove, some bolts are a bit hard to reach.
Posted: Mon Feb 07, 2011 3:25 pm |
cd-vs , dont suppose you have that bit of hose im after that goes from the head to the throttle body?
| *DEAD*206 Gti 138
Posted: Mon Feb 07, 2011 4:10 pm |
leigh_boy wrote: |
cd-vs , dont suppose you have that bit of hose im after that goes from the head to the throttle body? |
The engine breather hose?
No they always break as they get brittle with age.
Part number is 00001192T6 RE-SUCTION PIPE (Engine Breather Hose)
£21.01+ VAT
Posted: Mon Feb 07, 2011 4:38 pm |
i took mine apart tonight, strangely my seals look ok. but i suppose one of them could have been sucked in or something as 2 of them came off when i removed it so i couldnt see how they were fitted.
it was a bit of a mess however, dirty and grotty so ive given it a good clean and im going to get some new seals and a new throttle body seal tomorrow just to be on the safe side.
one thing that did worry me though. ran my finger aroudn the inside of the manifold and it came out black! is it normal for their to be this amount of grot lining the walls of the manifold?? engines done 65kish..
how did yours do with cleanliness?
