Online Now [477]:
Visitors: 476
Today: 170237
Total: 157637097
Forums › The Car › 206 Problems › Engine Movement
Engine Movement
dtm_martin24
PostPosted: Sun Feb 06, 2011 6:42 pm Up
My 206's engine seems to have a very rough idle and the engine moves about alot in the engine bay. I replaced the cambelt yesterday and found the left engine mount was loose and i've torqued it up now and it is better but it still moves alot. The engine seems rough even compared to my girlfriends mondeo tdci. Any Help Would Be Appreciated.
Peugeot 206 1.4 HDI Style 3dr
elcamino
PostPosted: Sun Feb 06, 2011 10:42 pm Up
May be the engine mounts need to be replaced mate.and what kinda engine you got?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
dtm_martin24
PostPosted: Mon Feb 07, 2011 1:26 am Up
1.4 hdi
kieron
PostPosted: Mon Feb 07, 2011 2:55 am Up
You say it rough? as in its running rough or what, and you did the timing belt yourself if it was a tooth out it run run abit rough
other that that it will be a worn mounth , give it a good pull to see if they is much movement
Account suspended
dtm_martin24
PostPosted: Fri Feb 11, 2011 5:41 pm Up
The belt is not a tooth out as i just checked it. There is also a slight burning smell just after the engine is started. Checked injector o rings and they are fine. By rough i mean it feels like a tank at idle but as soon as i touch the throttle it is fine.
ma.langan
PostPosted: Sat Feb 12, 2011 2:19 am Up
what is your idle rpm? could be knackerd idle control valve making it idle too slow hence the movement
Farmer T'aaron!
PostPosted: Sat Feb 12, 2011 4:50 am Up
You can't really tell if a mount is worn simply by pulling on the engine. Engine mounts are quite soft these days to make the car more refined.
mjsroofing
PostPosted: Sat Feb 12, 2011 7:55 am Up
mine is the same mate, bottom rear mount seems to be teh problem with mine, havnt fixed it yet, but by pulling it you can see clearly that it is worn/split etc
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
dtm_martin24
PostPosted: Sat Feb 12, 2011 6:18 pm Up
Thanks Guys, I'll have a look tommorow in the daylight. The Idle is around 800 rpm according to the tachometer.
